D16 turbo questions
You need larger injectors. The D series can handle a good 6 PSI or so on stock internal parts with good reliability, just need bigger injectors and a tune in addition to the mandatory turbo parts.
If you want more power... looking into Vitara Pistons and some Eagle rods.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sundownz »</TD></TR><TR><TD CLASS="quote">You need larger injectors. The D series can handle a good 6 PSI or so on stock internal parts with good reliability, just need bigger injectors and a tune in addition to the mandatory turbo parts.
If you want more power... looking into Vitara Pistons and some Eagle rods.</TD></TR></TABLE>
Ive seen d-series handle 210whp on stock internals. Some as high as 9psi. To the OP probably searching around turbod16.com is a good place to start.
WTF everyone is talking about psi like that has anything to do with anything
so you saying that 6 psi is safe regardless what turbo it is?
WRONG
a stock motor is safe up to 220 whp +-
that is on a good tune
if your on a **** tune than 180 whp might be the limits
it's all in the tune
this will get you started
https://honda-tech.com/zerothread?id=1643764
https://honda-tech.com/zerothread?id=1927070
https://honda-tech.com/zerothread?id=1478127
https://honda-tech.com/zerothread/878169
https://honda-tech.com/zerothread/1024174
WRONG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by man with one cam »</TD></TR><TR><TD CLASS="quote">Yes its all in the tune. There is no being safe then stock, anything else u do is unsafe for the motor. Yes you can boost and make 220 +- but there no reliably in it. Motors are made to handle wast its made for which is being stock. There are many factor beside a good tune. </TD></TR></TABLE>
as long as you take care of it than there is no reason why a 220+- whp SOHC-T cant last you years. just don't beat the **** out of it every time your in the car. and the same goes for stock. if you don't take care if it than it's not going to last.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by man with one cam »</TD></TR><TR><TD CLASS="quote">Whos not gonna beat the **** out it, Its fast.</TD></TR></TABLE>
well first off it's not "fast" it will be quick but definitely not in the fast category.
and anyone that's wanting to cake care of there car won't beat the **** out of it every time they get in the car.
there is just no real reason to race to every red light.
fast would be a 11sec 1/4
turbo a SOHC civic because it's a fun daily driver
you talking like it's not going to hold up
i saying that it can hold up if you take care of it
when i said racing to every red light i didn't mean literally racing
i mean just don't beat the **** out of it all day every day and your good
ya beat that **** from time to time because it will be quick and fun
however in moderation
the same thing with stock
don't cake care of it and drive like a bat out of hell all day every day and a stock motor won't last but a year or so
daily drive like a normal person and you probably won't even hit full boost
if you are trying to race a SOHC-T that is still stock?????
i would say 12.5 1/4 mile would be the quickest +-
but if you were to be racing it than why stay stock and why stay SOHC?
a stock SOHC that is used to race on a regular bases won't last very long.
turbo a SOHC civic because it makes a fun daily driver
there are people on here making over 400whp on SOHC built
