prothane, motor mount insert , press
Old Mar 24, 2007 | 02:36 PM
HmgLauj69's Avatar
Default prothane, motor mount insert , press
can the inner ring be pressed out? my prothane inserts dont fit
Old Mar 25, 2007 | 12:00 PM
Crispy's Avatar
Default Re: prothane, motor mount insert , press (HmgLauj69)
I'm not sure, but you can dremel it out. There was a writeup somewhere about filling your mounts with eurethene and the guy used a dremel tool
Old Mar 25, 2007 | 05:50 PM
drumking15's Avatar
yea...there is the outer base aluminium...then a steel sleeve and then the mount rubber...you need to get the steel sleeve out or else it wont fit in properly....i used a screw driver and hammer to hit the sleeve and break it...once its broken...used the screwdriver to bend it and itll come right out
Old Mar 26, 2007 | 09:37 AM
PA MATT's Avatar
Default Re: (drumking15)
Here's what I did. Take the blade off a hacksaw, put it on the inside of the mount, re-attach, then saw away at the inner sleeve. Once you have a cut, you can bend the sleeve around and pop it out of the mount. good luck
Mishako129
Mar 8, 2014 09:35 PM
fatfurious2
Mar 6, 2009 02:09 PM
komat
Dec 13, 2005 09:48 AM
Haruspex
Feb 19, 2005 08:51 AM
vinasity
Nov 2, 2003 02:59 PM
