driver side motor mount insert
Old 12-10-2005, 01:03 PM
komat's Avatar
Default driver side motor mount insert
im trying to install my driver side upper motor mount insert. But im having a hard time fitting the insert into the mount. It didnt come with any instruction saying that we have to trim it to make it fit.
does anyone know if we have to trim the mount to fit the insert?
Old 12-10-2005, 01:20 PM
RedEj8's Avatar
Default Re: driver side motor mount insert (komat)
Well on my buddys gsr's mount, the drivers side rubber was completly replaced with the polyurethane. If yours is like this, theres a steel band the rubber is connected to and you have to get that steel pressed out of the mount in order to install the center puck and side inserts.Or you can do it with the right tools.
Old 12-10-2005, 01:47 PM
komat's Avatar
Default Re: driver side motor mount insert (reddohcvtec)
thats the tranny upper mount
the driver side all you have to do is just insert the mount insert
Old 12-10-2005, 02:12 PM
A.E Motoring's Avatar
thought the knife was working lol
Old 12-12-2005, 11:54 PM
urnotfast's Avatar
your mount owns you. and my icy parking lot owned you the other night.
Old 12-13-2005, 05:20 AM
monicle's Avatar
Default Re: driver side motor mount insert (urnotfast)
use a vice and some oil to lube up the inserts. I assume youre taking about this one right?
Old 12-13-2005, 05:24 AM
allanonjj's Avatar
Default Re: driver side motor mount insert (monicle)
take the mount off the car
Old 12-13-2005, 07:32 AM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">use a vice and some oil to lube up the inserts. I assume youre taking about this one right?
Thats an EK mount. He has a EG.
Does the insert go to the upper timing belt mount or the AC mount?
I know a guy who was having the same problem. Turns out, he had the AC mount insert and he was trying to get it to fit into the timing belt mount.
Old 12-13-2005, 07:38 AM
idriveadelsol7's Avatar
All my mounts are either energy suspension/prothane inserted. Everything can be manually done with your hands except the driver side (upper by the timing belt) you need a press for this and trimming a bit my help. Try to trim a it like this ‘V’ the top of the ‘V’ is the outer (outside)
Old 12-13-2005, 09:48 AM
monicle's Avatar
Default Re: driver side motor mount insert (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke &raquo;</TD></TR><TR><TD CLASS="quote">
I know a guy who was having the same problem. Turns out, he had the AC mount insert and he was trying to get it to fit into the timing belt mount. </TD></TR></TABLE>
oh yeah eg. sorry.
Ninety-9 SE-L
Suspension & Brakes
04-17-2007 01:37 AM
Haruspex
02-19-2005 08:51 AM
AcCO12D95
03-21-2004 07:08 AM
turbospool
08-08-2003 11:49 PM
Quick Reply: driver side motor mount insert
