Motor Mount problem
Old Feb 18, 2005 | 04:40 PM
Haruspex's Avatar
Default Motor Mount problem
I went to install my ES inserts today, I got the front passenger side done fast. I got around to the drivers side and noticed the dumb-*** owner before me installed a passenger side mount on the drivers side, so obviously my inserts wont fit. My question is should I shell out the cash for the proper mount and slide my inserts in or will it work just as well if I fill the current mount w/ window weld. It looks like there's a few washers behind the mount as well, is the correct mount bigger than the passenger side mount?
thanks for the help,
-Alex
Old Feb 18, 2005 | 05:03 PM
FireMedic's Avatar
Default Re: Motor Mount problem (Fuzzado)
Do the right thing and get the propper mount for that side, the wrong mount might put it at an incorrect angle, or cause stress on a part which may result in failure later on... Also, I just did ES bushings in my mounts... Dont use those zipties that come with the kit, THEY WILL BREAK, use heavy duty zipties and wrap them around the whole mount.
Old Feb 18, 2005 | 05:06 PM
Haruspex's Avatar
Default Re: Motor Mount problem (FireMedic)
cool thanks for the help
also Im a bit of a Honda noob so Im not 100% on the interchangability of parts, will the drivers side torque mounts from any b-series work? How about any other Honda cars?
Old Feb 19, 2005 | 08:51 AM
FireMedic's Avatar
99-00 Civic Si
94-01 Integra ALL
Del SOL Si VTEC ONLY... so pretty much all B-Series equipped honda/acura cars
komat
Dec 13, 2005 09:48 AM
staticrex
Jan 14, 2005 03:34 PM
filtereds0ul
Dec 10, 2004 10:28 PM
Tire Monkey
May 1, 2004 12:38 PM
