Calling all "Frankenstiners" :o What is the average life expactancey of a B20 vtec
Old Mar 23, 2007 | 03:47 PM
solid1's Avatar
Default Calling all "Frankenstiners" :o What is the average life expactancey of a B20 vtec
I have hear all kinds of stuff about the CRV b20 block + b16 head combo. Most of which indicate that the frakenstine is a tourque monster (reletively of course) and uber quick, but will not do this reliably beyond a one year 30,000mile time span. Is this true? Or are they just parroting what Johnny's cousin that works at Mobil said.
Any Frankenstiner up in here?
Old Mar 23, 2007 | 03:52 PM
bleakdragonmage's Avatar
Default Re: Calling all "Frankenstiners" :o What is the average life expactancey of a B20 vtec (solid1)
ummm...dont know yet...i think my swap only has around 8-10k AT MOST...i know ive put about 4-5 on it since ive owned it and its still going strong..i mean...besides some normal maintnence and i have a seal leak(cam seal) that imma deal with tomorrow...but i mean its still running im kinda curious on this aspect too
Old Mar 23, 2007 | 04:17 PM
Luserkid's Avatar
Default Re: Calling all "Frankenstiners" :o What is the average life expactancey of a B20 vtec (bleakdragonm
The motor will be as good as the builder. You have a bad builder and bad maintenance schedule then youll probably see 10k if that. Have a good builder and good mantienance then you could see 100k. If its a stock setup then its as good as your mantienance.
Old Mar 23, 2007 | 04:18 PM
ARMED's Avatar
i had mine since 2003...
no problem at all....its still kicking and screaming..
i drove my car...about 4 times...back and forth...from chicago to CALI...never had no problem...
i guess it all depends on who built it...
Old Mar 23, 2007 | 04:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">The motor will be as good as the builder. You have a bad builder and bad maintenance schedule then youll probably see 10k if that. Have a good builder and good mantienance then you could see 100k. If its a stock setup then its as good as your mantienance. </TD></TR></TABLE>
so true!!...also...the motor is as good as the two pieces...if you manage to put together 2 with high mileage i can imagine it wouldnt last nearly as long as someones who pieces it together with really low miles...
Old Mar 23, 2007 | 04:35 PM
ek2k's Avatar
EXACTLY...It all depends on the builder...but then again the parts that you use and if you do stock sleeves or after market sleeves like Golden Eagle. There is a great post in the all motor section about building a reliable... lsv or b20v. You should check it out if you haven't done so already...
Old Mar 26, 2007 | 03:35 PM
jizzay34's Avatar
My b20 has been runnin for three yrs. One minor oil leak on the pan but took care of that.Other than that no probs just build it right and do the maintenance.
Old Mar 28, 2007 | 06:30 AM
t3st's Avatar
Default Re: Calling all "Frankenstiners" :o What is the average life expactancey of a B20 vtec (jizzay34)
my b20 is running for over 2 years now .. doing its maintenance on time and its going all good taking it every saturday to the track .. so build it right and do the maintance it will last as long as every honda engine ..
Old Mar 28, 2007 | 06:50 AM
chadalac1712's Avatar
i got a 166890 on my b20 . running strong as it did the time we built it. i keep royal purple oil in it and tranny etc. i change it every 2k miles though. new filter and oil. i take it n every 3k to be serviced. dads a machinc so i do it as much as possible
Old Mar 28, 2007 | 06:54 AM
CivicVX94's Avatar
the main reason people blow their ls/b20 vtec setups is b/c they have an entirely stock bottom end that has a redline of like 7.2K? and the vtec head allows them to make power beyond the redline of the bottom end. after beating it for a while, rod bolts stretch/break and **** happens.
if you use a stock bottom end, know it's limits. if you build right you shouldn't any issues, within reason.
for reference:
ls/b20 vtec info
http://hondaswap.com/general-t...nfo-8/
reliable ls/b20 vtec
https://honda-tech.com/zerothread?id=1676914
ultimate ls/b20 vtec parts/prices
https://honda-tech.com/zerothread?id=1812388
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chadalac1712 &raquo;</TD></TR><TR><TD CLASS="quote">i got a 166890 on my b20 . running strong as it did the time we built it. i keep royal purple oil in it and tranny etc. i change it every 2k miles though. new filter and oil. i take it n every 3k to be serviced. dads a machinc so i do it as much as possible </TD></TR></TABLE>
no offense, but what the hell do they do at a 3k service? comp/leak down test, valve lash? i can't think of anything that NEEDS to be checked every 3k..especially on a fresh engine. seems like an overkill, but i guess better safe than sorry.
Old Mar 28, 2007 | 07:19 AM
kuja396's Avatar
Default Re: Calling all "Frankenstiners" :o What is the average life expactancey of a B20 vtec (CivicVX94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek2k &raquo;</TD></TR><TR><TD CLASS="quote">EXACTLY...It all depends on the builder...but then again the parts that you use and if you do stock sleeves or after market sleeves like Golden Eagle. There is a great post in the all motor section about building a reliable... lsv or b20v. You should check it out if you haven't done so already...
1</TD></TR></TABLE>
This is the thead, great info in here https://honda-tech.com/zerothread?id=1676914
volcom_7_1
Jun 15, 2009 07:10 PM
immrtaltchnq
Oct 21, 2008 07:46 AM
xotic_crx
48
Oct 10, 2007 03:47 PM
95jdmdc4
Jun 22, 2006 09:04 PM
teamvirus
13
Oct 27, 2005 11:51 AM
