Bad idle only when warming up please help!!!!!!!!!!1
ive got a 95 gsr swap in my 99 coupe! no cel or anything but when i turn it on in the morning it idles above 2300 and then will jump up and down until it rests at normal idle! this whole process takes about 20 minutes or more before i drive the car at normal idle! once its warm it never does it again, so it cant be a vacum leak so i dunno what to do! any thoughts would help and be greatly appreciated thanks!
Re: (kleanlscivic)
i replaced the iac on my stock motor before but it idled crazy all the time! the gsr only idles when its warming up so i wouldn't think it could be the iac again, right?
Re: (skunkcoupe)
mine did it while it was warming up and then after it warmed up it ran fine, i have a b18b1 in my 99 civic. you said you already let all the bubbles in the radiator fluid come out?
Re: (kleanlscivic)
at cold start if the idle jumps its probly FITV. (fast idle thermo valve)
under the TB
take off the brass looking cap, screw in the white plastic cap all the way tight.
http://www.ef-honda.com/ben/Badidle.php
under the TB
Re: (THC07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC07 »</TD></TR><TR><TD CLASS="quote">at cold start if the idle jumps its probly FITV. (fast idle thermo valve)
under the TB
http://www.ef-honda.com/ben/Badidle.php</TD></TR></TABLE>
just what I was going to suggest....did this on mine and idles beutifully all the time now
under the TB
Re: (THC07)
under the TB
x3 on the fitv...
under the TB
x3 on the fitv...
Ef4doorwagon
17
04-06-2014 03:31 PM
steronz
10-16-2005 02:22 PM
