Broken VSS
My VSS stopped working one day. I pull it out, opened it up, and discovered that it has seized up. I bought a used VSS and swapped it in. It didn't work. I bought two other sensors and it didn't work. I'm guessing that there is something broken in the tranny? I don't know what gear in the tranny tha tthe gear on the VSS connects to. Help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvteclude »</TD></TR><TR><TD CLASS="quote">the vss goes off the diff. if your speedo stopped working there is another speedo control box thats in the dash that could be out. </TD></TR></TABLE>
I forgot to mention that it caused a CEL. So I don't think it could be anything with the cluster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvteclude »</TD></TR><TR><TD CLASS="quote">i hate to ask but was the harness plugged in all the way? also was the vss itself all the way down on the housing?</TD></TR></TABLE>
All the way down so that the mounting tab on the VSS was flush against the tranny. Harness plugged in tight.
ONEhaque
Oct 30, 2008 07:19 PM
Delano5050
May 5, 2007 08:52 AM
