What Ecu will work with both vtec/nonvtec?
Alright this is kinda confusing but hear me out,
I have a Built b18a and it will soon be a Ls/vtec Turbo, for now it will remain non-vtec untill I have the head built.
What obd1 ecu would I be able to use inorder to minimize problems?
I want to get a vtec ecu so while non-vtec It runs but, it throws some codes, no biggie.
But when the head is bolted Up i wont need to get it tuned right away untill I bolt the turbo up to it.
so pretty much what ecu could I use to run non-vtec, and DOhc Vtec w/o getting a basemap prior to boosting?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMB20TDA »</TD></TR><TR><TD CLASS="quote">soo I will require a form of engine managment no matter what?
It might just be easier to buy a Ls ecu and than wait.
Or you could just get a chipped ecu, have someone program it for the LS, and then when you upgrade to the vtec head, then get it programed for vtec. Instead of buying two different ecus.
</TD></TR></TABLE>Or you could just get a chipped ecu, have someone program it for the LS, and then when you upgrade to the vtec head, then get it programed for vtec. Instead of buying two different ecus.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">
Or you could just get a chipped ecu, have someone program it for the LS, and then when you upgrade to the vtec head, then get it programed for vtec. Instead of buying two different ecus.</TD></TR></TABLE>
+1
+1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMB20TDA »</TD></TR><TR><TD CLASS="quote">ill jsut buy self a obd1 Ls ecu and have it tuned for vtec later.</TD></TR></TABLE>
It will still have to be chipped either way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">
+1</TD></TR></TABLE>
+1 again
+1 again
well for now with the non-vtec/non turbo b18a/b it will run fine with Ls ecu.
But yea I thank you guys for your help, being the obd1 ls ecu;s are so much cheaper I think its the smarter route for now...
Addicted2Racing
10
Jan 27, 2004 04:29 PM
