D16Y3 Vtec????
My friend has a 99 civic with a D16Y3 in it. The valve cover does not say VTEC on it, but I was driving it and I swear it has a cross over at about 6000rpms. I just wondering. I know they make SOHC Vtec, and they say Vtec on the valve cover.
if i remember right, all the 96-00 d series valve covers are the same, and none say vtec on them regardless of if they have vtec or not. so it's possible, but i've never heard of the y3.
d16y3? wtf? do you mean "d16y8"? could be some grease covering up the side of the number 8, if its a y8, then YES it has VTEC
From Wikipedia:
D16Y8
Found in:
* 1996-2000 Honda Civic EX (USDM)
* 1996-1997 Honda del Sol Si
o Displacement : 1590 cm3
o Bore and Stroke : 75 mm X 90 mm
o Compression : 9.6:1
o Power : 127 hp @ 6600 rpm & 107 ft·lbf @ 5500 rpm
o Valvetrain : SOHC VTEC
o Head Code : P2J
o Piston Code: P2P
From Wikipedia:
D16Y8
Found in:
o Head Code : P2J
o Piston Code: P2P
what were the engine codes for the aussie d sereis motors that honda sold to land rover?????????? i forget it might be one og thos,
op look for a vtec solenoid couldnt miss it
hey fast turzac im leaving you a reply back becuase im bored... and im pretty excited about friggen vtech ness of the little honda i have.... and i figured out how to use this website
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown »</TD></TR><TR><TD CLASS="quote">a little bit of brake cleaner will clean this situation up
and the story</TD></TR></TABLE>
What???
and the story</TD></TR></TABLE>What???
lowblackdub
Sep 20, 2012 06:13 PM
