? about Tial 50 MM bov's....
Old Mar 9, 2007 | 09:33 AM
D15Bbigred's Avatar
Default ? about Tial 50 MM bov's....
what is the little spring on the inside for? like if i'm only going to run a max of 7.50 psi on my turbo which spring should i have? thnx for any help
Old Mar 9, 2007 | 09:37 AM
Schister66's Avatar
Man U FTW
The internal spring doesn't deal w/ the pressure you're going to run on your setup....it is determined by the amount of vaccuum at idle. Most Hondas take the 11lb spring. If you go to Tial, they have the chart
Old Mar 9, 2007 | 09:57 AM
D15Bbigred's Avatar
guess i need to get a different boost gauge cause it only reads boost only. k i'll make sure i get an 11lb spring
Old Mar 9, 2007 | 12:47 PM
alpha's Avatar
Default Re: (D15Bbigred)
Engine Vacuum Reading - Use Spring
Between:
-22 and -23 in/Hg - 12 Psi (-24 in/Hg )
-18 and -21 in/Hg - 11 Psi (-22 in/Hg )
-14 and -17 in/Hg - 9 Psi (-18 in/Hg )
-10 and -13 in/Hg - 7 Psi (-14 in/Hg )
Old Mar 10, 2007 | 02:49 PM
h22 civic's Avatar
Default Re: (alpha)
that tial blowoff is the most controversal blow off valve out t their you will get many different answers on the spring rate
Old Mar 10, 2007 | 04:12 PM
Schister66's Avatar
Man U FTW
Default Re: (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">that tial blowoff is the most controversal blow off valve out t their you will get many different answers on the spring rate </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alpha &raquo;</TD></TR><TR><TD CLASS="quote">Engine Vacuum Reading - Use Spring
Between:
-10 and -13 in/Hg - 7 Psi (-14 in/Hg )</TD></TR></TABLE>
I dont know how it could get any simpler than that....
Old Mar 10, 2007 | 05:31 PM
h22 civic's Avatar
Default Re: (Schister66)
pretty simple haa ok i just built a brand new fresh k series turbo what valve do i go with???????
Old Mar 10, 2007 | 05:37 PM
8herout's Avatar
no valves but you can go with a 50mm bov
whatever vacuum your motor is pulling just compare it to the chart on top of your post
Old Mar 11, 2007 | 03:41 AM
I.C.C.'s Avatar
i have the 7psi spring in mine and it works fine for me..... 20-22vac at idle and so far up to 30psi boost...
Old Mar 11, 2007 | 08:50 AM
D15Bbigred's Avatar
thnx for the for the info so far guys. i bought a better boost gauge that shows the vaccum. and I'll just read the chart accordingly.
Old Mar 11, 2007 | 08:38 PM
h22 civic's Avatar
Default Re: (8herout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8herout &raquo;</TD></TR><TR><TD CLASS="quote">no valves but you can go with a 50mm bov
whatever vacuum your motor is pulling just compare it to the chart on top of your post</TD></TR></TABLE>
did ya see the part that said brand new fresh motor meaning never started so dont know what it is vacuming ...thats the prob people are having they are told to buy one valve then start having probs when their car aint vacing what they originally thought
Old Mar 11, 2007 | 09:48 PM
8herout's Avatar
oh god, good luck on your valve
Old Mar 11, 2007 | 10:05 PM
alpha's Avatar
Most Honda's will want an 11 Psi spring
pcguy760
Jul 8, 2011 09:08 AM
Jonny Black
Sep 13, 2005 07:58 PM
.RTErnie
Jul 7, 2005 08:31 PM
Bimmerman
May 7, 2005 06:45 PM
NORCALCVC
Feb 15, 2005 11:57 PM
