stainless steel clutch lines
I found this web site http://www.fastlineperformance.com/clutchline.htm
but it dont have any lines for an accord. Is there another site that might have one, and I saw awhile back in a mag a site where you can make your own ss lines can someone piont me in the right direction
I'm pretty sure my 6th gen has hard lines from the clutch master cylinder, all the way to the slave cylinder... I think most other accords should be the same. Those lines would be pretty pointless.
There HAS to be at least a short flexible section to allow for the motion of the engine/tranny assembly. Here's the line for a '98, the rubber section is towards the top-left of the picture.
I would normally think so, but I've replaced that line before when my mastercylinder went out, and there wasn't any soft lines. Looking on my current Accord, it's solid from the slave all the way around the rear of the block. I didn't get a chance to look around the firewall near the master.
I know my 95 EX had that short soft line from the passenger side of the engine bay to the slave cylinder.
Not sure where you can get a SS version but people have removed the entire hard line for a SS one, mostly when doing auto-to-manual swaps. Seen it on Civics, Integras and a couple Accords. You can probably get some of the parts from AN Pluming.
Look towards the end of this thread in the Prelude forum and there's tons of pics & info about doing a full SS clutch line. I did mine and it worked you very well.
--https://honda-tech.com/zerothread?id=1210919
I found that same website and wanted one of those for my accord.
I ended up getting one from this site: http://www.tasauto.com for my 5th gen.
i actually noticed a significant difference in clutch engagement, I like it
Thanks all for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">I know my 95 EX had that short soft line from the passenger side of the engine bay to the slave cylinder.
Not sure where you can get a SS version but people have removed the entire hard line for a SS one, mostly when doing auto-to-manual swaps. Seen it on Civics, Integras and a couple Accords. You can probably get some of the parts from AN Pluming.</TD></TR></TABLE>
Thanks that is what I was looking for and forgot the name
Just a thought if I get a line from the clutch m/c all the way to the slave cyl, how will that make my pedal feel mushey or no?
Rahzel00
Aug 7, 2015 03:41 PM
98savage
Mar 14, 2007 03:26 PM
Heinz57
Nov 12, 2003 02:55 PM
