Swap Won't Start?
Old Feb 27, 2007 | 04:46 PM
EKHWhat's Avatar
Default Swap Won't Start?
I have had a JDM H22A in my EK for about five months.
I recently took it out to replace the timing belt/tensioner conversion, clutch, flywheel, and transmission.
I put the motor back in, and it doesnt start.
When I put the timing belt back on I noticed that the intake cam is a little off, but when I notched it another tooth over, or was further then it was before I had notched it over another tooth.
Could having the balancer shaft belt missaligned have anything to do with the motor not turning over? It was previously ran without a balancer shaft belt, and ran fine.
Old Feb 28, 2007 | 11:18 AM
Bakeoff's Avatar
Default Re: Swap Won't Start? (EKHWhat)
need some more info.
The balancer shafts won't affect starting. IT will just make the thing vibrate like a **** if it's off at all.
Does it turn over and not start, or not turn over at all? Any noise?
Old Feb 28, 2007 | 08:01 PM
EKHWhat's Avatar
It turns over, but doesn't start.
Lots of noise.
It's got spark, and its got fuel preassure.
Old Feb 28, 2007 | 08:03 PM
high_revs's Avatar
sounds like you forgot to plug something in maybe....do you have injector pulse?
its nothing to do with the balancer shafts, forget that idea.
[713]
May 14, 2012 03:23 PM
slowsinglecam
11
Dec 24, 2011 07:59 AM
green_si
18
Mar 3, 2010 03:24 PM
f22kid
Jul 17, 2009 09:47 AM
rokestah
Feb 3, 2003 04:20 PM
