OBD on B16
im converting a b16a obd 0 to obd1 so i can just plug it into my eg. but my obd1 harness's knock sensor doesnt reach. what kind of wire should i use to extend it? anyone thats been in this situation please tell me what else i will have to modify. and also, the tranny is going to be obd2. so how would i moidify it?
thanks.
thanks.
You will need the correct driver side engine mount to attach the motor mount too.
That was one problem I ran into.
What ecu are you running because you may not even need the knock sensor. I didn't with a chipped P28.
Get a 92-95 ex/si harness and you will have vtec wires but I had a 92 cx so mine was prewired to shock tower.
93-95 you will have to run vtec wires and o2 wires. But then again I just got a wb so I don't use my stock o2.
That was the main issues that delayed me and it was a bitch searching for info on obd0 into eg so I had to figure alot out on my own.
Try to source a sir II or better head or think about your lost motion assemblies as they are the weak link but a little tapping isn't bad.
If I think of anything else I had to do I will let you know.
Also the tranny should just bolt up and go no need to worry about changing anything.
Good luck.
Good luck.
4door93civic
Apr 11, 2007 10:16 PM
jdmeg9
Dec 17, 2006 06:58 AM
