xsi conversion
Old Sep 17, 2008 | 08:40 AM
josh564738291's Avatar
Default xsi conversion
hey guys, i plan on swapping an obdII b16a into my 93 integra ls. i am going to use my ls tranny since its recently new and to save money. could someone tell me what i need to swap the vtec engine into my car. do i need a special wiring harness. will the motor bolt in with stock motor mounts? i know i need the b16 ecu. any info could help thanks a lot.
Old Sep 17, 2008 | 09:06 AM
neardon's Avatar
I'm a Jackass
Default Re: xsi conversion (josh564738291)
You dont want obd2 you want to stay obd1. If you stay obd1 the motor will drop right in and you will just need to run a few wires to the ecu for vtec.
Old Sep 17, 2008 | 09:15 AM
pokmijn's Avatar
Default Re: xsi conversion (neardon)
you could run that motor but just use your engine harness and use an obd1 ecu or get a obd1-obd2 jumper...youll have to run the vtec wires also, and may be the knock sensor too cause i dont think your car has one but im not sure someone confirm.
Old Sep 17, 2008 | 10:38 AM
1992blueGSR's Avatar
Default Re: xsi conversion (pokmijn)
pokmijn, i belive it does have a knock sensor, the original motor out of my 92 gsr had one
thangnhocngheo
Jul 26, 2011 11:17 PM
tougetuned_ef
Engine Management and Tuning
Jun 17, 2010 01:51 PM
rugbyplaya85
Nov 5, 2005 07:13 AM
slammedteg
May 1, 2004 09:12 AM
b18bme
Apr 25, 2004 11:17 AM
