itr motor's surging. irratic idle. help
Old Feb 23, 2007 | 09:10 PM
itr1244's Avatar
Default itr motor's surging. irratic idle. help
motor was rebuilt last summer.
ctr pistons, rm cams..
-car spits black stuff off tail pipe. (water+black stuff) not oil
-car wants to stall on cold start.
-after car's warmed up it idles erratically rpm goes from 800-(1250-1300)rpm
if i disconnect the tps sensor it idles high at 1500 rpm.
i failed e test cuz of it won't idle steady.
what could be the problem ???
thanks
Old Feb 24, 2007 | 06:50 AM
itr1244's Avatar
Default Re: itr motor's surging. irratic idle. help (itr1244)
bump
Old Feb 24, 2007 | 08:58 AM
goldegg's Avatar
Im not sure if this is related,
but I had a very similar problem on my sr20det 240sx and it turned out to be a bad fuel injector and a bent fuel rail.
when i put in new injectors and a new rail the car idled as perfect as a brand new car.
Old Feb 24, 2007 | 09:02 AM
itr1244's Avatar
Default Re: (goldegg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goldegg &raquo;</TD></TR><TR><TD CLASS="quote">Im not sure if this is related,
when i put in new injectors and a new rail the car idled as perfect as a brand new car.</TD></TR></TABLE>
hmm i do have new injectors .. i should check the wiring again. i guess
Old Feb 24, 2007 | 04:38 PM
inspyral's Avatar
Do you have any vacuum leaks? Is the IACV good? Do you have any air in your cooling system?
Old Feb 25, 2007 | 08:36 AM
itr1244's Avatar
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">Do you have any vacuum leaks? Is the IACV good? Do you have any air in your cooling system?</TD></TR></TABLE>
no vacuum leaks i think.
which way do i need to turn the screw to lower the rpm?
Old Feb 26, 2007 | 09:27 AM
goldegg's Avatar
Default Re: (itr1244)
clockwise
br8crumb
May 22, 2014 04:53 PM
Blue94Accord
Oct 2, 2009 12:11 PM
boostedK20a2
May 3, 2006 08:31 AM
MintFlavored
Nov 3, 2002 06:57 PM
