OBD0 to OBD1 on OBD2 engine what distributor?
No Big Whoop
Hey guys.
I have a d16Y7 that I am currently using a OBD0 distributor and ECU.
I have decided to convert to OBD1. I would like to use an OBD1 distributor but the mounting bolts don't line up with the head (OBD2) and I don't want to hack the distributor. I have an OBD2 distributor but it uses an external crank sensor which I don't have on the Y7 anymore ( I removed it when I did the swap)
So what D series OBD2 ECU has all the sensors in it?
Thanks in advance.
Thanks in advance.
No Big Whoop
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist »</TD></TR><TR><TD CLASS="quote">You can use the obd2 dissy that crank sensor isnt used on obd1 ecus </TD></TR></TABLE>
Are you 100% on this one? So why do OBD1 distributors have a crank angle sensor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maxbore.com »</TD></TR><TR><TD CLASS="quote">
Are you 100% on this one? So why do OBD1 distributors have a crank angle sensor? </TD></TR></TABLE>
So does the obd2 ones, if u look up the wires both dissy have the same number of wires going in and out. We had a 94 gsr obd1 with a 2000 itr swap, and dissy with the crank sensor unpluged. Im 99% sure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker »</TD></TR><TR><TD CLASS="quote">the D15b7 will work .</TD></TR></TABLE>
redracer1024
Aug 15, 2007 01:39 PM
Adam West
May 8, 2006 03:47 AM
