Crank angle sensor (obd2)
Old Jul 26, 2004 | 08:28 AM
BlkSIvic's Avatar
Default Crank angle sensor (obd2)
What type of problem will I encounter if I didn't use this sensor with a obd2 ecu?
Old Jul 26, 2004 | 10:11 AM
Muckman's Avatar
Moderator in Chief
Default Re: Crank angle sensor (BlkSIvic)
Im pretty sure the ECU needs to know where the crank is to know where the engine is in the stroke.
Old Jul 26, 2004 | 11:54 AM
simple4012's Avatar
New User
Default Re: Crank angle sensor (Muckman)
the car wont start
Old Jul 26, 2004 | 05:47 PM
PHiZ's Avatar
Default Re: Crank angle sensor (simple4012)
CKF sensor you mean.
-PHiZ
Old Jul 26, 2004 | 10:12 PM
EG6 SiR's Avatar
It will put you in limp mode.
Old Aug 8, 2004 | 03:55 PM
IntegraB18's Avatar
Default Re: Crank angle sensor (EG6 SiR)
Whats limp mode? I'm having the same problem.
Old Aug 8, 2004 | 05:32 PM
-faded-'s Avatar
Default Re: Crank angle sensor (IntegraB18)
just convert it over to obd1 and not worry about it
Old Aug 10, 2004 | 06:22 PM
crx-t's Avatar
Default Re: Crank angle sensor (hybridlsR)
how do you convert it to a obd1?
Old Aug 10, 2004 | 08:15 PM
-faded-'s Avatar
Default Re: Crank angle sensor (crx-t)
obd2 to obd1 jumper harness and a obd1 ecu
Old Aug 19, 2004 | 11:00 PM
5.0killa's Avatar
So if you convert your car to obd1 you dont need the ckf any more? I thought you had to change the distributor or some ****? I hope you don't need it anymore because i hate that f*ckin thing.
Old Aug 20, 2004 | 07:27 AM
Madspeed's Avatar
Default Re: Crank angle sensor (5.0killa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5.0killa &raquo;</TD></TR><TR><TD CLASS="quote">So if you convert your car to obd1 you dont need the ckf any more? I thought you had to change the distributor or some ****? I hope you don't need it anymore because i hate that f*ckin thing.</TD></TR></TABLE>
if you just use a "jumper harness" and an OBD1 computer your "under the hood" harness stays the same so you keep your distributer (sorry)...the jumper harness plugs in where your stock computer plugs in and then connects to the OBD1 computer.....this is the easiest way to tune also...and no you wont need the crank angle sensor anymore.
Old Aug 20, 2004 | 01:20 PM
5.0killa's Avatar
Default Re: Crank angle sensor (Madspeed)
what about the crank Fluctuation sensor
Old Aug 21, 2004 | 02:00 PM
Dragline's Avatar
Just wire the crank angle sensor to the cam angle sensor. I've done it several time with no performance problems
Old Aug 21, 2004 | 11:26 PM
ej0513's Avatar
Default Re: Crank angle sensor (dragline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline &raquo;</TD></TR><TR><TD CLASS="quote">Just wire the crank angle sensor to the cam angle sensor. I've done it several time with no performance problems </TD></TR></TABLE>
how did you do this? do you think if i did this i would pass visual for California Certification (BAR)?
Old Sep 1, 2004 | 10:12 AM
gotjesus's Avatar
Default Re: Crank angle sensor (ej0513)
Hi. i actually found this thread very helpful... i have a obd2 engine in my 94 cx hatch. im using the stock obd1 harness that was on the 1.5 l motor. i am running a obd1 ecu, i had to run knock sensor, vtec wires and o2 sensor. as fasr as the crank sensor, i did not need it since my obd1 ecu wont look for it. so i just clipped the wires, and runs fine. no codes...
sikcrx80
May 1, 2023 05:16 PM
Spaceballsthelunchbox
Feb 23, 2007 07:22 AM
strictly.business
Nov 25, 2006 09:05 PM
Civic
Dec 14, 2003 11:51 AM
XMarkGuerillaX
May 2, 2003 01:06 PM
