94 Accord Electrical Problem
I was attempting to locate a short in one of my speaker wires and accidently (& stupidly) hit an exposed wire against metal. This seem to have shorted our something in the wiring. The antenna went down and I lost power in both the radio and the clock. I checked the radio fuse and it is fine. I check the car fuse for the radio and it is fine. If I push the button on the clock the clock comes on, but the clock and the radio will not come on when I turn the car on. Is there a switch that controls power from the ignition switch to the radio? Any hidden fuses along the circuit? An ideas? Any help greatly appreciate.
thanks
Mike
thanks
Mike
Found the problem, but thought I woul share it in case someone else has such a simple problem. I found a reference to a "backup fuse" and then found the 2nd radio "backup fuse" under the hood.
I come from a family of idiots. It is not my fault
