clock memory loss problem
Old Jan 30, 2002 | 07:35 PM
glock's Avatar
New User
Default clock memory loss problem
Hi,
Tonight I installed one of those flat antennas that go in your back window because my stock antenna wire is broken. The flat amplified antenna required power, so I spliced into the radio fuse in the fuse box on the drivers side. When I went to put the center console back in my radio turned off, and now it won't turn back on, and now my clock doesn't keep the time after I turn off my car. It just resets to 1:00. I removed the antenna and everything and it still doesn't hold time and the radio still doesn't turn on. I checked the radio fuse and it's fine. Any ideas guys?
Thanks in advance,
~glock
Old Jan 30, 2002 | 09:10 PM
CanadaCivicSIR's Avatar
New User
Default Re: clock memory loss problem (glock)
It sounds like you lost the 12V constant power to your radio.
On all radios there are two wires with fuses: An Ignition or Accesory wire and a Constant fuse wire.
The Constant power wire is what powers the radio and keeps the memory for the clock.
Check all your fuses under the dash and under the hood, sometimes they group the fuses together for multiple things. Like Cig lighter and so on.
The Acc wire is like a remote turn on they use for amps. When the ignition turns on it signals the radio to turn on and then it is ran off your constant power wire.
[Modified by CanadaCivicSIR, 10:11 PM 1/30/2002]
Old Jan 30, 2002 | 10:32 PM
datap1mp's Avatar
lol you're BEAT man shoulda went to PRUVEN or BOOMER
Old Jan 31, 2002 | 11:28 AM
glock's Avatar
New User
Default Re: clock memory loss problem (CanadaCivicSIR)
Does anyone know what color or where I can find this 12v constant wire?
Thanks.
Old Jan 31, 2002 | 09:27 PM
datap1mp's Avatar
check the fuses on the back of the radio
Old Feb 1, 2002 | 09:36 PM
o_Rage_o's Avatar
Default Re: clock memory loss problem (datap1mp)
Starter Black/White Ignition Switch
12V Constant N/A Battery
Ignition Black/Yellow Ignition Switch
Heater Yellow Ignition Switch
Accessory White/Red Ignition Switch
Tach Blue At Coil
Brake Switch Hot N/A Brake Switch
Brake Switch Cold Green/White Brake Switch
Courtesy Lights(-) Green/Red Near Fuse Box
Parking Lights(+) Red/Green Steering Column
Door Lock (-) 3 wire Black/White Left Kick Panel
Door Unlock (-) 3 wire Black/Red Left Kick Panel
Trunk Release (-) Green/Black Left Kick Panel
Power Windows LF Up (+) Red/Yellow Driver's Switch
Power Windows LF Down (+) Red/Blue Driver's Switch
Power Windows RF Up (+) Blue/Yellow Driver's Switch
Power Windows RF Down (+) Blue/Green Driver's Switch
Sunroof Close (+) N/A At Switch
Sunroof Open (+) N/A At Switch
Horn(-) Green/Red Steering Column
Full wiring colors...hope they help! Just test at back of radio, make sure that it's constant 12v )
Kenneth.Honda94
Audio / Security / Video
Sep 16, 2014 10:04 AM
hatchinprogress
Mar 1, 2012 03:30 PM
karrar55
Mar 30, 2011 05:08 AM
pinkspider
Oct 23, 2006 02:11 PM
glock
Feb 2, 2002 10:31 AM
