Radio and clock keep reseting???
Old Dec 21, 2007 | 08:29 AM
91EF_Si's Avatar
Default Radio and clock keep reseting???
Got a weird problem here. Everytime I turn the car off, then then turn the car back on my radio and clock reset back to default. Any ideas? Radio harness is fine, cuz when I had it in my other civic it never did this...
Old Dec 21, 2007 | 08:36 AM
Koyoloeor's Avatar
Default Re: Radio and clock keep reseting??? (91EF_Si)
sounds like bad battery connection to me
Old Dec 21, 2007 | 08:39 AM
91EF_Si's Avatar
Default Re: Radio and clock keep reseting??? (Koyoloeor)
checked that.
Old Dec 21, 2007 | 08:42 AM
B18C_EJ8's Avatar
You have a blown backup fuse under the hood.
Old Dec 21, 2007 | 09:48 AM
91EF_Si's Avatar
Default Re: (B18C_EJ8)
wats the name of that fuse?
Old Dec 21, 2007 | 10:09 AM
B18C_EJ8's Avatar
"Backup", "Radio", etc...
It's going to be the one that's blown when you check all of the fuses with a multimeter.
Old Dec 21, 2007 | 11:45 AM
94_DC4's Avatar
It's a 7.5A fuse.
Old Dec 22, 2007 | 06:25 PM
eskimo10's Avatar
Well when I blew my fuse under the hood it didn't turn my radio on at all. You might want to check your ground wire it could be loose, or check your power wires I know that my buddy had a problem like this and his constant 12V and switched 12V wires were wired backwards and when I fixed it he no longer had the problem.
Old Dec 23, 2007 | 08:44 AM
fcm's Avatar
fcm
Old Fart
Default Re: (eskimo10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eskimo10 &raquo;</TD></TR><TR><TD CLASS="quote">Well when I blew my fuse under the hood it didn't turn my radio on at all. You might want to check your ground wire it could be loose, or check your power wires I know that my buddy had a problem like this and his constant 12V and switched 12V wires were wired backwards and when I fixed it he no longer had the problem.</TD></TR></TABLE> Is your HU an aftermarket HU?
On the stock HU, and some low powered aftermarket HUs the constant power is for memory only, so the HU will work but will not hold memory when turned off.
Most aftermarket HUs use the constant power as the HUs main power and the HUs acc. input is just a "trigger", just like an amp, the main power is constant and the turn on is the switched lead from the HU. 94
Modified by fcm at 10:06 AM 12/23/2007
Kenneth.Honda94
Audio / Security / Video
Sep 16, 2014 10:04 AM
SumOne
Oct 15, 2006 07:32 PM
H.
Aug 24, 2006 10:19 PM
ScottieA
Jan 23, 2006 12:01 PM
integra*RS*
12
Oct 19, 2003 06:12 PM
