Junkyard/ECU WIRE HARNESS people, I need you!!!!
Old Feb 9, 2007 | 01:39 PM
BlackHXCoupe's Avatar
Default Junkyard/ECU WIRE HARNESS people, I need you!!!!
I'm in DESPERATE need for the EGR plug off a 97 HX MANUAL... Turns out the damn Auto and Manual use a different EGR plug, go figure. I can't find this damn thing ANYWHERE locally, the Intake manifold I got came with the sensor, but not the PLUG itself. So if anyone could help me out it would be great.
Reason is I'm smogging soon, and I'm throwing 5 codes.
Codes are:
P1491 - Manufacturer Control Auxilary Emissions Control
P0500 - Vehicle Speed Sensor A Malfunction
P1166 - Manufacturer fuel air Metering (Still on after I erase Codes)
P0401 - EGR Flow Insufficient
P0401 - " " " "
The cars throwing all those codes. It's a COMPLETELY stock 97 Civic HX that I did a manual conversion on it. I'm running the Manual ECU and IACV fix. How can I fix this ASAP?? I don't know what any of that crap means.
Modified by BlackHXCoupe at 4:52 PM 2/13/2007
Old Feb 9, 2007 | 01:51 PM
4drgsr96's Avatar
Default Re: Junkyard/ECU WIRE HARNESS people, I need you!!!! (BlackHXCoupe)
look in the phone book for import junkyards.
Old Feb 9, 2007 | 01:59 PM
Luserkid's Avatar
Default Re: Junkyard/ECU WIRE HARNESS people, I need you!!!! (96civb18c1)
What does the plug look like and how is it different from auto to manual? I never seen a sensor that was different from auto and manuals.
Old Feb 9, 2007 | 03:47 PM
Default Re: Junkyard/ECU WIRE HARNESS people, I need you!!!! (Luserkid)
The Auto one is 3 wire. And the Manual one looks bigger, there's 5 pins on it so I suppose it's a 5 wire one. I'll snap some pics here as soon as I can. But I work in a couple of minutes.
Old Feb 10, 2007 | 12:24 PM
Bump just in case anyone knows the answer without pics. I'll get pics ASAP!
Old Feb 12, 2007 | 11:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackHXCoupe &raquo;</TD></TR><TR><TD CLASS="quote">Bump just in case anyone knows the answer without pics. I'll get pics ASAP!</TD></TR></TABLE>
Old Feb 13, 2007 | 02:56 PM
Bump for some help!!!
Old Feb 13, 2007 | 03:52 PM
Updated, pics soon!
Old Feb 14, 2007 | 12:39 PM
no love on V-Day?
Old Feb 15, 2007 | 11:03 AM
Old Feb 15, 2007 | 08:41 PM
DETALZ's Avatar
bump
Old Feb 16, 2007 | 12:18 PM
Default Re: Junkyard/ECU WIRE HARNESS people, I need you!!!! (fnkrew93)
someones gotta know
Old Feb 18, 2007 | 06:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fnkrew93 &raquo;</TD></TR><TR><TD CLASS="quote">bump
Old Feb 18, 2007 | 07:31 PM
gato5254's Avatar
hey could email a pic i have a bunch of plugs from an old 96 cx 5 mt harness and a 96 jdm itr or send me ur email address and i'll send you some pics of what i got.
Old Feb 19, 2007 | 11:24 AM
Default Re: Junkyard/ECU WIRE HARNESS people, I need you!!!! (gato5254)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gato5254 &raquo;</TD></TR><TR><TD CLASS="quote">hey could email a pic i have a bunch of plugs from an old 96 cx 5 mt harness and a 96 jdm itr or send me ur email address and i'll send you some pics of what i got.</TD></TR></TABLE>
PM replied.
Old Feb 19, 2007 | 03:58 PM
gato5254's Avatar
email sent
Old Feb 19, 2007 | 04:02 PM
B16B_coupe's Avatar
HRD PKR
do u have a pic of the plug u need?
Old Feb 19, 2007 | 04:03 PM
SiREJ8's Avatar
swap the egr then??? just a suggestion but i wouldn't think they'd be different!
Old Feb 20, 2007 | 05:51 AM
Default Re: (SiREJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiREJ8 &raquo;</TD></TR><TR><TD CLASS="quote">swap the egr then??? just a suggestion but i wouldn't think they'd be different!</TD></TR></TABLE>
Yea I have both and they are definately different. One has lines routing back into the IM and one doesn't. (the one I'm using does) I've been told it's the O2 sensor, somebody is currently working on fixing the problem on his car, if it works then its the same for me. Hopefully it is. If it were just the EGR that would be tough, because the other one is about 5 pins I believe, and the one I'm currently using is only 2. And figuring out how to wire has been impossible. So hopefully it doesn't need to be done.
Lildj2983
Oct 30, 2014 10:54 AM
maystg
Dec 17, 2012 02:15 PM
TiLLiiCoLLaPsE
Mar 3, 2011 11:40 AM
devonic
Sep 11, 2003 08:39 AM
