Squealing from passenger side wheel/suspension area - need ideas for what to check
Old Feb 7, 2007 | 03:56 PM
jefe's Avatar
Default Squealing from passenger side wheel/suspension area - need ideas for what to check
I am looking for things to check on my 93 Civic HB DX...
I have had this crazy come and go as it pleases crazy loud squealing noise that i have narrowed down to coming from my passenger side wheel well.
I just recently re-lubed all the brake parts thinking it was brake related but it hasn't helped.
Not always, but it seems to start after I make a turn. If I come to a complete stop, it will stop, the noise slowing down with the momentum...but eventually will come back whenever it feels like.
I know the area where the noise is coming from, just need some ideas for what to check that might cause such a noise.
CV joints typically cause knocking sounds, right? What about ball joints, tie rods, etc?
Old Feb 7, 2007 | 05:39 PM
jefe's Avatar
Default Re: Squealing from passenger side wheel/suspension area - need ideas for what to check (jefe)
bump.
Old Feb 8, 2007 | 11:17 AM
jefe's Avatar
one last bump for this stupid post.
Old Feb 8, 2007 | 11:20 AM
92LX K20swap's Avatar
Are you sure your tire isnt rubbing the wheel well? I get a crazy squealing sound when I turn, cause my 215/45/17's are way too big for the wheel well.
Old Feb 11, 2007 | 02:07 PM
jefe's Avatar
Default Re: Squealing from passenger side wheel/suspension area - need ideas for what to check (92LX K20swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92LX K20swap &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure your tire isnt rubbing the wheel well? I get a crazy squealing sound when I turn, cause my 215/45/17's are way too big for the wheel well.</TD></TR></TABLE>
Pretty sure that isnt the case...I am only running 15's.
Like I said, the noise is really random. I can't reproduce it at will. It comes and goes as pleases. Once it starts, I can come to a complete stop and it will quit. Once I get going again, it's fine. Then comes back whenever it wants.
Old Feb 11, 2007 | 03:36 PM
punk_0333's Avatar
I just changed my brakes last week, new pads and rotors and this just started happening to me aswell. Its only when i make a left hand turn though. Bump for some help.
Old Feb 11, 2007 | 05:01 PM
excivicboy96's Avatar
I have that same problem. I suspect that it is the tire itself. I will know when I get my tires rotated in the next few days. You should try that as well.
Old Feb 11, 2007 | 05:03 PM
B16B_coupe's Avatar
HRD PKR
is ur rotor backing plate hitting?
worder
11
Sep 23, 2011 05:25 AM
bigsnorlax
Sep 30, 2009 10:00 PM
JMelt4
Jun 6, 2007 12:14 PM
carbonlaced
Jun 27, 2006 10:02 AM
ZexyAccord
Sep 28, 2004 06:26 AM
