Flashing maintenance required sign?
Old Feb 5, 2007 | 05:20 PM
turbotaylor's Avatar
Default Flashing maintenance required sign?
Well I just replaced my radiator in my 2000 integra gs auto the other day. The first day nothing was wrong but the second day when I started my car in the morning and the maintenance required sign came on and started to flash. It only flashes for like 20 seconds then the maintenance required sign gos off. Now it does it every time i start the car. Does anyone know what this could be? Thanks for your time.
Old Feb 5, 2007 | 05:30 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: Flashing maintenance required sign? (turbotaylor)
NO!!
Old Feb 5, 2007 | 05:35 PM
EGY8's Avatar
How long have u had the car? Is this the first time the maint light came on?
Old Feb 5, 2007 | 05:44 PM
integra racr04's Avatar
well it doesnt necessarily mean that something is wrong, how many miles are on the car??
Old Feb 5, 2007 | 05:47 PM
Default Re: Flashing maintenance required sign? (integra racr04)
I have had it for about a year and a half and it has almost 82,000 miles
Old Feb 5, 2007 | 05:52 PM
EGY8's Avatar
I am assuming it is just a coincidence that this happened around the same time he did some maintenance. It is probably just the normal every 7,500 mile timed warning. I believe it is every 7,500 miles. Check under the dask under the steering wheel and there should be a little square button u can press.
Old Feb 5, 2007 | 05:53 PM
EGY8's Avatar
Is this the first time that it has come on? How many miles have u put on it since u bought it?
Old Feb 5, 2007 | 05:56 PM
Default Re: Flashing maintenance required sign? (eldog99)
I have put about 10,000 miles on it and it have never come on before.
Old Feb 5, 2007 | 06:01 PM
EGY8's Avatar
I know on my 99 GSR the light is on mileage timer. Like i said before there is little square button under the dash that will remove the light instead of having to take it to the dealership and pay them to do it. Just turn the key on for power in the car without starting it and hold down the button for a few seconds, it should flash and turn off.
Old Feb 5, 2007 | 07:07 PM
GSRdude's Avatar
your right, but the light he says flashes then goes off. when my maintanace light comes on it stays on till I hit that button. so I really dont think that is iit, but I wouldn't worry about it since it goes away.
Old Feb 5, 2007 | 08:24 PM
have u done a timing belt yet?? or anything your supposed to do at around that mileage??? maintience wise...
Old Feb 5, 2007 | 08:26 PM
numbnuts22715's Avatar
Default Re: Flashing maintenance required sign? (GSRdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRdude &raquo;</TD></TR><TR><TD CLASS="quote">your right, but the light he says flashes then goes off. when my maintanace light comes on it stays on till I hit that button. so I really dont think that is iit, but I wouldn't worry about it since it goes away.</TD></TR></TABLE>
it flashes for a while, then it lights up and stays on.
to make it stop, you do the same thing as you would if it were to stay on.
Old Feb 5, 2007 | 08:31 PM
GSRdude's Avatar
Default Re: Flashing maintenance required sign? (numbnuts22715)
I would try it. It doesn't hurt to hit the button when you might not need to. It might however reset the mileage count(unsure).
Old Feb 5, 2007 | 08:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRdude &raquo;</TD></TR><TR><TD CLASS="quote">I would try it. It doesn't hurt to hit the button when you might not need to. It might however reset the mileage count(unsure).</TD></TR></TABLE>
yes, it will reset the mileage count for the maintenance required light.
There really isnt a point to this light, it just helps you keep track of your scheduled maintenance and whatnot... oil changes, certain mileage checkups/tuneups and whatnot.
There isnt anything wrong with your car, this light isnt even really tied into anything.. its just programmed to come on at certain mileage increments.
Old Feb 5, 2007 | 09:06 PM
nomotivdc4's Avatar
i think the light just comes on to warn you that you may need a maintance soon..thats what mine did..just hold down the button until it goes away as others have stated above and it'll go away..
Old Feb 5, 2007 | 09:10 PM
berb_15's Avatar
The recomended maintenance procedures and mileages can be found in the owners manual if you were interested in seeing what honda recomends that you do at this point, they are also in the chilton manual, but as stated above you don't HAVE to do anything or follow the light....
Old Feb 5, 2007 | 09:12 PM
GSRdude's Avatar
Default Re: Flashing maintenance required sign? (berb_15)
I actually don't do anything myself, but reset it.
Old Feb 5, 2007 | 10:59 PM
grjp1988's Avatar
Mine has came on 2 times since i have had mine i just reach under the steering wheel and hold the button in till it goes out and then shut off ur car then turn it on and it goes away for another long time
Old Feb 5, 2007 | 11:35 PM
GoldCoin's Avatar
Default Re:
you shouldve searched . this has been covered a million times.
press the button.
thats it..
the maintaince light means your a retard .
Old Feb 6, 2007 | 03:36 PM
bendw99's Avatar
Wow, lots of wrong answers thus far. The "MAINTENCE REQUIRED" light is just a reminder to change your oil. It is on a mileage timmer and it will come on and start flashing at about 4500 miles and then stay on when you hit 5000 miles (these used to be the old maintence specs on hondas).
Look under the dash, there is a square button thats tucked up under the dash a bit. Turn your car on and hold the button down for about 5 seconds. That will reset the light.
Again, all that does is remind you that its been 5000 miles since maintaince was last performed.
~Ben
crvpimpin
Jan 13, 2007 01:48 PM
aes62679
Jul 21, 2005 01:56 PM
StrtMeUp01
Jan 16, 2005 06:50 PM
Rick
Oct 23, 2003 09:25 AM
SexyTeg
Sep 30, 2002 11:55 AM
