problems with my crv
Old Jan 4, 2007 | 10:42 AM
crvpimpin's Avatar
Default problems with my crv
i havent been able to realy track it down yet but
i was driving the other day and i turned on my blinker to turn and the car died. i restarted it and then it imediatly died agian. so i waited a few seconds then tryed to restart agian and it started, but not far it died agian no blinker
and i had to wait a few minutes this time befor it would restart the car wasat normal temps and i figuredit had somthing to do with something over heating because it was fine after i let it cool for a few minutes, also the srs light came on after this second time not sure if it was related
but it was doing fine for the last few days then driving home from work today it happened agian just like befor but the drive home is only like no more than 5 miles and would have barely had time to warm up so im realy confused as to what this might be
any guess's as to what i might wanna check would be good
(i already checked the fuses)
thanks
Old Jan 5, 2007 | 06:25 PM
igotthaspirit's Avatar
Default Re: problems with my crv (crvpimpin)
Your blinker switch is tied into the SRS cable reel behind the steering wheel. Its likely that the problem lies there, however ive never seen a faulty cable reel cause a car to shut off. Its possible you have two problems. Your CRV is probably one of the ones that has the ignition switch recall. I recommend writing down your VIN number and calling a Honda dealer to check to see if you have any recalls that havent been done.
Old Jan 13, 2007 | 01:48 PM
crvpimpin's Avatar
Default Re: problems with my crv (igotthaspirit)
thanks i'll do that asap
97civic2
Mar 1, 2013 06:07 AM
MinuteRice
Mar 28, 2007 11:38 AM
turbotaylor
Feb 6, 2007 03:36 PM
crvpimpin
Jan 15, 2007 01:56 PM
95BlkGSR
Oct 21, 2004 06:38 AM
