CTR Waterpump
to be more specific, all b series vtec pumps are the same. what you have to worry about is getting the right belt. since you have a b16b you'll need a b18c belt.
to be more specific (or ****), a B-series VTEC H2O pump has 22 teeth while a non VTEC has 25. VTEC motors rev up higher....they would foam up the coolant at 8k rpm if they were not 22t.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 »</TD></TR><TR><TD CLASS="quote">to be more specific (or ****), a B-series VTEC H2O pump has 22 teeth while a non VTEC has 25. VTEC motors rev up higher....they would foam up the coolant at 8k rpm if they were not 22t.</TD></TR></TABLE>
nonvtec has 19 teeth
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">
nonvtec has 19 teeth</TD></TR></TABLE>
Correct smaller dia makes the pump run faster.
Which makes me think...so we get like an .01 hp from having a bigger waterpump gear. ha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99hondacura »</TD></TR><TR><TD CLASS="quote">why would u need a b18c belt for the ctr</TD></TR></TABLE>
because b16b and b18 deck heights are the same. b16/b17 have shorter deck heights.
From: down the street,bythe river in the van, co, united states
o ok i get it so does water pump matter lik using a b16a2 o a itr o ctr r all of them the same o is there a difference in the performance they do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99hondacura »</TD></TR><TR><TD CLASS="quote">o ok i get it so does water pump matter lik using a b16a2 o a itr o ctr r all of them the same o is there a difference in the performance they do</TD></TR></TABLE>
like i said earlier, all b series vtec pumps are the same and all non vtec b series pumps are the same. the vtec pumps spin slower at higher rpms to better control the water/coolant.
crazyguy
21
Dec 28, 2007 03:55 PM
V8K1LLER
Jan 18, 2005 11:38 AM
