CTR Waterpump
Old Feb 4, 2007 | 01:44 AM
Stealthycivicsi's Avatar
Default CTR Waterpump
So about time for TB/Water pump in my CTR... and I am assuming that CTR/ITR TB and water pump are the same? Correct me if I am wrong on this.
Old Feb 4, 2007 | 04:11 AM
eg6ajk's Avatar
Default Re: CTR Waterpump (Stealthycivicsi)
yes, ITR/CTR/GSR are all the same!
Old Feb 4, 2007 | 01:54 PM
doood's Avatar
been there done that
Default Re: CTR Waterpump (eg6ajk)
to be more specific, all b series vtec pumps are the same. what you have to worry about is getting the right belt. since you have a b16b you'll need a b18c belt.
Old Feb 4, 2007 | 09:16 PM
EG2Driver's Avatar
Default Re: CTR Waterpump (doood)
to be more specific (or ****), a B-series VTEC H2O pump has 22 teeth while a non VTEC has 25. VTEC motors rev up higher....they would foam up the coolant at 8k rpm if they were not 22t.
Old Feb 5, 2007 | 12:04 AM
s2kdre's Avatar
Default Re: CTR Waterpump (DeadEnd9009)
tru that
Old Feb 5, 2007 | 11:39 AM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 &raquo;</TD></TR><TR><TD CLASS="quote">to be more specific (or ****), a B-series VTEC H2O pump has 22 teeth while a non VTEC has 25. VTEC motors rev up higher....they would foam up the coolant at 8k rpm if they were not 22t.</TD></TR></TABLE>
nonvtec has 19 teeth
Old Feb 5, 2007 | 11:50 AM
citrus3000psi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">
nonvtec has 19 teeth</TD></TR></TABLE>
Correct smaller dia makes the pump run faster.
Which makes me think...so we get like an .01 hp from having a bigger waterpump gear. ha
Old Feb 5, 2007 | 12:39 PM
99hondacura's Avatar
From: down the street,bythe river in the van, co, united states
why would u need a b18c belt for the ctr
Old Feb 5, 2007 | 12:46 PM
doood's Avatar
Default Re: (99hondacura)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99hondacura &raquo;</TD></TR><TR><TD CLASS="quote">why would u need a b18c belt for the ctr</TD></TR></TABLE>
because b16b and b18 deck heights are the same. b16/b17 have shorter deck heights.
Old Feb 5, 2007 | 01:03 PM
o ok i get it so does water pump matter lik using a b16a2 o a itr o ctr r all of them the same o is there a difference in the performance they do
Old Feb 5, 2007 | 01:10 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99hondacura &raquo;</TD></TR><TR><TD CLASS="quote">o ok i get it so does water pump matter lik using a b16a2 o a itr o ctr r all of them the same o is there a difference in the performance they do</TD></TR></TABLE>
like i said earlier, all b series vtec pumps are the same and all non vtec b series pumps are the same. the vtec pumps spin slower at higher rpms to better control the water/coolant.
Old Feb 5, 2007 | 01:13 PM
o ok thanks for explaing it to me
crazyguy
21
Dec 28, 2007 03:55 PM
b20vtech
Dec 16, 2005 02:23 PM
urbanbrown
Jun 25, 2005 06:38 AM
V8K1LLER
Jan 18, 2005 11:38 AM
JoseCuervo
Jan 26, 2004 04:42 PM
