really quick radio que. just need a answer
Old Feb 2, 2007 | 06:43 AM
dthug's Avatar
Default really quick radio que. just need a answer
ok i have a 92 hatch and i want to use a 00 si radio. i have the plug beind the radio with the wires coming out of it.
how can i make this work in my hatch? do i just snip off the plug off my harness and color match it to the si radio harness? are they all color matched, will i have extra wires.
i wanna get this done right now cuz i have nothign to do and searching for this is hard
thanks
Old Feb 2, 2007 | 07:07 AM
pdiggitydogg's Avatar
Since you have the 98+ connector w/ wiring, just match it up
http://www.installdr.com/Harnesses/HA-Wiring.pdf
...searching is easy if you try a little
Old Feb 6, 2007 | 10:18 AM
dthug's Avatar
Default Re: (pdiggitydogg)
hmm the wires were to short to splice into my harness.
what car can i cut the plugs out from and have it for a perfect match for my harness, and be able to use that link you provided. cuz looking at the old plug it didnt have the wires in the same spot in that diagram
Old Feb 6, 2007 | 10:31 AM
BlueIntegraBoy's Avatar
Default Re: (dthug)
The wires from the Si radio plug are too short? Or your radio harness?
What I plan to do if I pick up an 02-06 CRV radio was to buy a reverse harness for the 96+ Honda radio and a harness for my 92-95 Civic. Splice them together, and plug and play.
Reverse Harness
Harness
Old Feb 6, 2007 | 10:35 AM
dthug's Avatar
Default Re: (BlueIntegraBoy)
where can i get that at?
cuz i was told it was a 03 crv radio but it looks JUST LIKE my cousins 00 si radio.
Old Feb 6, 2007 | 10:39 AM
Default Re: (dthug)
Any good audio store should have them. The ones in the pic are eBay ones which I plan to order from.
But if the wires coming from the Si plug are too short, any 98+ Honda will have the same radio plug.
Old Feb 6, 2007 | 10:43 AM
dthug's Avatar
so you think i can go to pepboys and get a reverse plug or w.e from a 98+ honda and splice it to my stock eg harness.?
btw the plugs taht were to short were the ones that came with the plug from the radio
Old Feb 6, 2007 | 10:50 AM
Default Re: (dthug)
Yes, if you don't mind splicing into the radio harness, you can get a reverse harness and splice. The reason why I would buy the reverse harness and harness is if I wanted to switch back to my ITR radio. I wouldn't have to resplice again.
I'm not sure if Pepboys carries the reverse harness.
nbcivic
Audio / Security / Video
May 20, 2010 01:36 PM
JHP
13
Mar 9, 2009 12:20 PM
JHP
Mar 9, 2009 02:57 AM
iENJOIfallen
22
Aug 16, 2008 02:38 PM
pcater
Oct 8, 2004 08:29 AM
