b16a2 dyno chart
Old Jan 30, 2007 | 02:42 PM
iaem1's Avatar
Default b16a2 dyno chart
my b16a2 dyno chart
Old Jan 30, 2007 | 02:43 PM
shibiku's Avatar
Default Re: b16a2 dyno chart (iaem1)
nice power, but what's with the air/fuel ?
Old Jan 30, 2007 | 02:49 PM
H9Omega's Avatar
hmm that a/f is odd.
Old Jan 30, 2007 | 02:51 PM
iaem1's Avatar
this was the base run on race gas
Old Jan 30, 2007 | 02:56 PM
hondachris1994's Avatar
Default Re: (iaem1)
and they say b16's are torqueless
nice numbers man, whats the setup?
Old Jan 30, 2007 | 03:08 PM
iaem1's Avatar
to much **** .its a money pit
but yes i love the torque
Old Jan 30, 2007 | 03:15 PM
turbociviccoupe's Avatar
Default Re: (iaem1)
what boost?
Old Jan 30, 2007 | 03:21 PM
mk2machine's Avatar
Default Re: (turbociviccoupe)
yeah that air fuel is wierd. Get it back up at 14.7 and inject some alcohol.
Old Jan 30, 2007 | 03:22 PM
mk2machine's Avatar
Default Re: (mk2machine)
just curious. I just wanna hear some general answers not super specific. What do these cars have for idle hp to the wheels?
Old Jan 30, 2007 | 03:23 PM
iaem1's Avatar
Old Jan 30, 2007 | 03:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mk2machine &raquo;</TD></TR><TR><TD CLASS="quote">yeah that air fuel is wierd. Get it back up at 14.7 and inject some alcohol.</TD></TR></TABLE>
huh? it looks ok on the high ends. 14.7? do you want him to blow it up?
Old Jan 30, 2007 | 03:26 PM
bore? stroked? compression?turbo? turbo size?
Old Jan 30, 2007 | 03:27 PM
mk2machine's Avatar
you realize that 14.7 is sea-level a/f mixture. And by the way anybody who has ever seen an engine run rich knows that it isnt gonna blow up. theres only so much oxygen being sucked into the chamber and it will not burn fuel past 14.7 If you run it rich than you will just burn up your cat. If you run it wicked lean than you will burn the 02 sensor. My car runs 14.7 a/f with alcohol injection with an intercooler and aftercooler with a 32 psi boost and its fine.
Old Jan 30, 2007 | 03:32 PM
iaem1's Avatar
i wont do 14.7 to risky in my case
84mm bore
9:1 je
eagle rods
gsr cam
garret t3/t4
Old Jan 30, 2007 | 03:34 PM
this guy is from the bay dude...14.7 afr means its running lean...what the hell are you talking about? and you dont need alcohol injection on a honda unless you are running very high boost. you just need to up the octane if your pinging.
Old Feb 1, 2007 | 09:40 AM
iaem1's Avatar
x2 14.7 is lean
rep the bay
imports automotive
Aug 23, 2006 08:47 AM
teri_vti
Apr 14, 2005 05:54 PM
Maxime
Jul 26, 2003 01:42 PM
Javier23
Mar 18, 2003 03:59 AM
quikrpm'z
Jul 28, 2001 09:21 AM
