Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
this doesnt really pertain to the 01-05 civic but if theres any HID gurus here i need some help
Old Jan 30, 2007 | 10:51 AM
Jon Vito's Avatar
Default this doesnt really pertain to the 01-05 civic but if theres any HID gurus here i need some help
ok so i have mchulloch (spelling?) 6k hid kit. well awhile ago one of them went out and it turned out to be a relay. i thought it was a ballast but someone helped me diagnos it as the relay. but what its doing right now is the right one will come on and the left one wont, then after a few minutes the left one comes on. anyone got a clue? could it just be the cold weather, bad relay again or the ballast is going out?
its a 6k kit if that matters. thanks
Old Jan 30, 2007 | 11:12 AM
Jon Vito's Avatar
anyone? would like to fix this problem
Old Jan 30, 2007 | 11:22 AM
toyomatt84's Avatar
Sanji
You waited all of 21 minutes to bump this thread. We're not your on-call tech. service, bud.
The problem sounds to be in the relay, like it's having capacitor problems. It might just need a new capacitor to build the necessary power. It also might be that you're having a short in the connection between the relay and the ballast, that's causing a redirection of power. Check the wiring to see if there's any cracks/splits in the outer shell, then if that does nothing, swap the ballasts from driver's side to passenger's side, and see if that won't change a thing.
Old Jan 30, 2007 | 11:32 AM
Jon Vito's Avatar
thanks and im trying to solve this problem in the little time i have between my day classes and night classes.
Old Jan 30, 2007 | 12:54 PM
Jer'rome's Avatar
Default Re: (Jon Vito)
well from my rescearch on HIDplanet.com..... you get what you pay for... say no to kits...
on the real thou I think your ballast is going, but check your connections again and try another relay
Old Jan 30, 2007 | 01:17 PM
fventura03's Avatar
Default Re: (Jer'rome)
i had this problem with some prolumen 6000k kit i had a couple of years ago. i sent it back, and they said it worked fine. when i got it back, it still did the same thing, and they wouldn't give me a refund. i eventually threw them out.
try getting a refund and get a better HID kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jer’rome &raquo;</TD></TR><TR><TD CLASS="quote">you get what you pay for... say no to kits... </TD></TR></TABLE>
very untrue, my catz 4300k has been problem free for about 1.5yrs now.
Old Jan 30, 2007 | 06:24 PM
Jon Vito's Avatar
i bought it used off of a friend last summer. but ive been thinking about going with a tsx retrofit i guess this might be my sign lol. i think ill diagnos the problem and just hope its a relay. ill keep yall posted
Old Jan 31, 2007 | 07:55 PM
Jon Vito's Avatar
turned out to be a bad ballast if anyone cares now im in search of one
Old Feb 1, 2007 | 08:39 AM
Curiouz_G's Avatar
the kit i got from umnitza for my old HID setup was perfect... so not all kits are crappy. wouldnt a bad ballast not generate any light at all?
Old Feb 1, 2007 | 10:40 AM
Jon Vito's Avatar
it stopped working all together yesterday and when i got 2 my buddies shop we took off the front bumper turned em on the passenger side one was making the noise that they make and the driver was making none.
Old Feb 4, 2007 | 12:12 AM
Thizzed Out's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon Vito &raquo;</TD></TR><TR><TD CLASS="quote">it stopped working all together yesterday and when i got 2 my buddies shop we took off the front bumper turned em on the passenger side one was making the noise that they make and the driver was making none. </TD></TR></TABLE>
maybe the ballast was wet? mine got wet and stopped working but then started again. YES its a sign you need to switch over to an retro. TSX's are good, and also have a cool cutoff color line.
Old Feb 4, 2007 | 07:05 AM
blouisgod's Avatar
how is the glare on the kit?
Old Feb 5, 2007 | 03:56 PM
Jon Vito's Avatar
nah it couldnt be its just wet, its had plenty of chances to dry out by now and still i got nothing. so i took the bullet and ordered another one. came in today they sent me the wrong one lol so now i sent it back out and hopefully ill have 2 headlights in no time
cHILL9210
Lighting
Dec 15, 2011 09:14 PM
Rover2cool
Mar 28, 2010 02:26 PM
nathanjohnson2009
Apr 3, 2009 04:11 PM
turbo dx
27
Mar 28, 2009 09:21 AM
97ekcoupe
Mar 23, 2007 04:28 PM
