Lighting HID/Xenon kits, Retrofits and Associated Topics
HID one side keeps going out.
Old Dec 8, 2011 | 03:15 PM
cHILL9210's Avatar
Default HID one side keeps going out.
Im having the same issue with my ddm tuning hid kit. I checked all grounds and connections,battery, alternator are all strong. Cant seem to figure out the issue.
Input please
Old Dec 9, 2011 | 07:25 AM
Joon Joon's Avatar
Default Re: HID one side keeps going out.
so it'll be on then just turn off?? if thats the case, the ballast or bulb is going bad... if one just doesnt turn on when you turn them on, then you need to run a relay harness.. the amperage the hids need to turn on is much higher than halogens, so it wont fire up the ballast.. you need to run a relay harness..
Old Dec 12, 2011 | 03:04 PM
jdm89crxhf's Avatar
thank you i am having the same problem but i belive its the ballast
Old Dec 15, 2011 | 09:14 PM
EJ2B16's Avatar
relay/wiring harness.
first switch the ballast and see if the problem follows the ballast. if it does then you just need a new ballast. if not then its a relay problem
PPWLUDE
Jan 24, 2010 03:35 PM
dth0ng69
Lighting
Dec 11, 2009 07:41 PM
vtek9
Lighting
Nov 14, 2007 12:54 PM
