What is wrong with my engine in this video?
Old May 17, 2002 | 07:22 AM
Audio18's Avatar
Default What is wrong with my engine in this video?
I cannot figure out where the whining noise is coming from on my car. I have already posted about this problem, and I have have gotten quite a few good suggestions. However, I still can't fix it. For more detail, check this post:
https://honda-tech.com/zerothread?id=184312
Check out the video and tell me what you think:
http://home.attbi.com/~audio18/MOV00440.MPG
Listen for the slight whine in the background while accelerating. It is getting louder everyday. It is much louder in person than it is in the video.
Old May 17, 2002 | 08:16 AM
prelude-bb3's Avatar
Default Re: What is wrong with my engine in this video? (Audio18)
sounds horrible,i know i hear every low sense of my lude,but what it is?...try resetting ECU and drive again,if it doesnt work check all vaccum line of correct connection plugs if loose (even their color),i think the normal things like oil,water,etc u´ve checked before...
Old May 17, 2002 | 09:22 AM
Audio18's Avatar
Default Re: What is wrong with my engine in this video? (prelude-bb3)
I have some longer videos, and I will post them later. The noise is the only high pitched little whistle in the background. It starts about 1 second into the video and squeals until the end. I have checked everything on the car as far as fluids, belt tension, whatever. I even cleaned out the intake manifold with cleaner blown through the tb.
Since many of the vacuum lines are under the manifold, is there any easier way to get to them or check for leaks?
I will upload more video when I get a chance.
Old May 17, 2002 | 09:49 AM
Koori's Avatar
Do you have a short ram or something? My intake whistles when I accelerate when I'm just driving normally...... I checked the video like 10 times and that's all it sounds like to me.
Old May 17, 2002 | 10:34 AM
Default Re: What is wrong with my engine in this video? (Hadji)
its not loud in the video and a high tone too,but i know what he mean,its a second not normal sound overlaying the engine accelerating sound
Old May 17, 2002 | 11:54 AM
Gerst240's Avatar
is that noise after you let off the clutch ?
Old May 17, 2002 | 07:36 PM
Honda4CX-T's Avatar
Yep sounds like a CAI system to me as well, it whistles when accelerating RPM dependant >>>
Old May 17, 2002 | 07:54 PM
RenoRacing's Avatar
Default Re: What is wrong with my engine in this video? (Honda4CX-R)
my car does that at any rpm above like 2500, just a humming/whining noise, it's just the air going into the throttlebody in my case.
Old May 17, 2002 | 09:47 PM
mantic6t9's Avatar
Default Re: What is wrong with my engine in this video? (HavokRacing)
yep sounds like my aem shorty.
Old May 17, 2002 | 11:18 PM
90civichbsi's Avatar
Default Re: What is wrong with my engine in this video? (mantic6t9)
mine makes this sound even when i take my intake off straight through the tb, but i have had intake for 4 years, and it just started makin that noise about 8 months ago. i think i need a valve adjustment, ill see if that fixes it. the wierd thing is the sound goes away and comes back at random times
i really dont think think its anything to worry about, its just freakin annoying
Old May 18, 2002 | 05:17 PM
Audio18's Avatar
Default Re: What is wrong with my engine in this video? (90civichbsi)
Well I am glad to hear that I am not the only one experiencing this problem, however, I don't know how much longer I can stand it. If it is the sound rushing into the throttle body and intake manifold, then what can I do to fix that.
I know it has nothing to do with the intake, because it is louder without it. Everyday it gets louder and louder though. The car is incredibly quiet at idle, and the valves do not need adjustment. In fact, the motor is one of the quietest honda motors I have ever heard.
I might end up removing the intake manifold and throttle body at some point to inspect them because the sound is embarrasing. Either that, or I could just put the resonator box back on the intake to mask the sound.
[Modified by Audio18, 9:52 PM 5/18/2002]
Inextricabledrvr
Honda Civic (2001 - 2005)
22
Jan 31, 2011 07:40 PM
zeplin
16
Dec 31, 2008 07:22 AM
del sol1658
16
Aug 21, 2006 11:27 AM
j-rome
35
Jul 5, 2006 01:11 PM
