b20 vtec turbos. post em up
Old Jan 29, 2007 | 08:46 PM
b20powereDA's Avatar
Default b20 vtec turbos. post em up
im curious how many of u guys are running b20vtec turbo and what the buikld consists of. also, the kind of care its in and times/#'s would be great. i was an all motor guy but i drive a DA and i jus got an 89 integra as a daily and im deciding to go turbo and i didnt see any sense in swapping the motor. cause im gonna end up sleeving the block anyways. thanks in advance
Old Jan 30, 2007 | 01:10 AM
B20VTI's Avatar
Default Re: b20 vtec turbos. post em up (b20powereDA)
540hp @16psi - Havnt taken it to the track yet, will do this summer
Benson sleeved 83mm B20 block
89mm Benson balanced and micropolished crank
CP 9-1 pistons/rings, Eagle 3/8 rods, ACL bearings
New OEM oil pump, new pick-up, new waterpump
ARP head studs and Cometic head gasket
New SuperTech valves, dual springs and titanium retainers
B16 VTEC head with 3 angle valve job, new seals, surfaced, all done by
PortFlow
CTR intake and exhaust cams, AEM 5 bolt cam gears
New STR fuel rail and new 1000cc RC Injectors
Edlebrock Victor X with stock throttle body, sensors and vtec selenoid
Oil pump adaptor with ls/vtec line in place
external coil plug setup
New timing belt, harmonic balancer
Driveshaft shop stage 3 driveshafts
SPA gauges
Motec M4 pro ECU
Full Race Stage 3 Pro-am Kit
Thermal exhaust
Old Jan 30, 2007 | 08:04 AM
2000BoostedEX's Avatar
Default Re: b20 vtec turbos. post em up (B20VTI)
496hp and 320 tq at 18psi on pump
655 and 476tq at 27psi on c16
golden eagle sleeved block
manley turbo tuff rods
je 9:1 pistons
ported/polished gsr head
manley valves
rev valvesprings and retainers
full race prostreet exh. mani
sc6176e
3" dp/ 2.75" exhaust
3" ic piping
big precision ic
1000cc precision inj.
hondata s200
T1 TUNED
Modified by 2000BoostedEX at 9:52 AM 1/30/2007
Old Jan 30, 2007 | 08:29 AM
Tuesday Club's Avatar
Default Re: b20 vtec turbos. post em up (2000BoostedEX)
Anyone rockin' low boost w/ stock sleeves?
Old Jan 30, 2007 | 08:46 AM
da_dude's Avatar
One of my friend have a b20 vtec turbo. Everything is stock. Only thing add was skunk2 intake manifold, rc 440cc, and a peice togather turbo kit. Kit include SFP turbo manifold, sc61 turbo, 38mm tial wastegate, greddy type s bov with custom IC piping, ebay intercooler, custom 3 inch DP and exhaust. Tune with hondata s300. Car made 281 whp and 211 lb of troque @ 10 psi. I'm also building a b20vtec turbo. Hope to make over 300 hp on stock block with stock gsr head. Only internal with be change is the gsr cam for itr cam.
Old Jan 30, 2007 | 02:31 PM
psikotc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20VTI &raquo;</TD></TR><TR><TD CLASS="quote">540hp @16psi - Havnt taken it to the track yet, will do this summer
PortFlow
SPA gauges
Motec M4 pro ECU
Thermal exhaust
</TD></TR></TABLE>Very nice, Very nice! APPLAUSE, APPLAUSE!
Old Jan 30, 2007 | 02:37 PM
A.E Motoring's Avatar
Default Re: b20 vtec turbos. post em up (psikotc)
wat turbo is that? t3/t67 H.O? P trim wheel?
Old Jan 30, 2007 | 09:18 PM
Default Re: b20 vtec turbos. post em up (Dual Cam Racing)
very nice so far. keep em coming. gives me somethig to look forward to
Old Jan 30, 2007 | 10:34 PM
dj_honda's Avatar
Default Re: b20 vtec turbos. post em up (Tuesday Club)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tuesday Club &raquo;</TD></TR><TR><TD CLASS="quote">Anyone rockin' low boost w/ stock sleeves?</TD></TR></TABLE>
I am running 18psi on a GT28RS on a stock block b20b (non-vtec). arp headstuds/oem hg , blox manifold, precision 250 ic, tial 38/50, and i made my own 3 inch dp to 3 inch exhaust straight back. Street tuned on UD, no dyno #'s but I ran 111mph trap in an EG hatch. My guess is 250+whp...?
Old Jan 31, 2007 | 12:22 AM
B20VTI's Avatar
Default Re: b20 vtec turbos. post em up (dj_honda)
Hey dude yeh t3/t67 HO .82 a/r
Old Jan 31, 2007 | 09:07 AM
beautiful
I recently acquired a stock B20z w/ &gt;17k miles, and I want to boost just a lil. I'm glad it has been done safely....Now I can feel comfortable doing it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dj_honda &raquo;</TD></TR><TR><TD CLASS="quote">
I am running 18psi on a GT28RS on a stock block b20b (non-vtec). arp headstuds/oem hg , blox manifold, precision 250 ic, tial 38/50, and i made my own 3 inch dp to 3 inch exhaust straight back. Street tuned on UD, no dyno #'s but I ran 111mph trap in an EG hatch. My guess is 250+whp...?</TD></TR></TABLE>
Old Jan 31, 2007 | 01:18 PM
Kenshou Motorsports's Avatar
stock b20 bottm end w/block gaurd & arp rod bolts.
stock b16a2 head
inline pro turbo kit t3/to4e 60 trim
inline fuel pump
550cc injectors (super low duty cycle )
267 wheel horspower & 216 torque @9psi tuned on crome
(shop crx, 2328 w/driver)
Modified by turbo0021 at 3:26 PM 1/31/2007
Old Feb 1, 2007 | 05:38 PM
Peter Shen's Avatar
this is the nicest EK i've seen in a long long time
good choice on the ECU.. i see the Motec distributor mod
are those BBS rims? what's the size/offset?
well done man
Old Feb 8, 2007 | 02:21 PM
Default Re: b20 vtec turbos. post em up (Peter Shen)
there's no way in hell this is all the b20vtec turbo builds. post more!!!!
B20VTI
Nov 28, 2006 11:06 AM
B20VTI
Oct 19, 2006 04:37 PM
B20VTI
May 25, 2006 10:29 PM
B18C5civic
Mar 14, 2006 10:46 AM
B18C5civic
Oct 20, 2005 11:58 PM
