del sol si d16z6 vtec not engaging
Old Jan 29, 2007 | 01:00 AM
Eg2707's Avatar
Default del sol si d16z6 vtec not engaging
well i got this car sept last year..and i dont think i ever felt vtec in this thing..i had 3 vtec cars in the past..the tach has been broken ever since i got it..so i was jus shiftin by sound..but now that i fixed it..i went from 1st all the way up to 7rpm..no crossover..and i think its always been like that..i dunno if the previous owner screwed me over..but heres wat i know..it has a vtec solenoid knock sensor wires running sumwhere..i checked the ecu..its a p28..no check engine lights at all..the engine runs pefect..stable idle..but i just dont understand why the vtec dont engage..help me out please
Old Jan 29, 2007 | 01:39 AM
sol2hatch's Avatar
Default Re: del sol si d16z6 vtec not engaging (Eg2707)
SOHC VTEC is just not that noticeable. What other VTEC cars did you own? If you have an intake, then you might be able to hear it, but you prob wont feel it.
Old Jan 29, 2007 | 03:31 AM
Syndacate's Avatar
Hook a test light up between the VTEC solenoid and the ECU...pin A4 I believe? Look it up in a Helms.
If it lights up when you hit VTEC, you know the ECU is sending out the signal to engage the solenoid.
If that's good, plug that back in 'n leave it alone.
Then go to the solenoid side of things. Cut the power wire going to the solenoid and touch it to the positive battery terminal, see if the solenoid clicks/engages when you touch it, and see if it goes back when you release it.
See where you are from there.
EDIT:
There's nothing really big in the VTEC system that would constitute the owner "screwing you."
Just out of curiosity, what other VTEC motors did you own? You do realize that the D-series have the least noticeable crossover points out of any of the VTEC motors. The JDM D15B is more noticeable than the D16Z6...I believe there's a ZC in some form that's VTEC, and I don't know anything about the ZC .
Old Jan 29, 2007 | 10:03 AM
MR_SI's Avatar
you have to reallllly have an ear to hear a stock d series vtec engage. i mean u can feel it but BARELY. my buddy had a 99 ex with a d16y8 and he couldnt even tell i just told him it engaged fine because i could feel it at the right rpms. you want to notice it get a b16
Old Jan 29, 2007 | 04:25 PM
Eg2707's Avatar
the motors i had were a 92 gsr integra with the b17...i had a 93 integra with a b18c1 and also a 95 eg hatchback with a b18c1..my boi has a 95 civic ex same motor d16z6 and u can hear the crossover with just a short ram stock motor..mine is the same..but i dont hear nothin at all.. and
"There's nothing really big in the VTEC system that would constitute the owner "screwing you.""
( the fact i bought that up.is because the rear disc brakes were swapped with sum drum brakes and my ebrake cable dont even work...i know for a fact its a Si and not a S)
Old Jan 29, 2007 | 05:21 PM
92ehatch's Avatar
i dunno why everyone says you cant hear vtec on a sohc. i can hear mine, loud and clear...in fact it screams pretty loud.
things ive noticed that will cause it not to engage
faulty map sensor, tps out of calibration, (both cause idle issues tho)
low oil, low oil pressure, low gas, clogged vtec solenoid screen.
Old Jan 30, 2007 | 08:46 PM
Eg2707's Avatar
any more possible things?
Old Jan 30, 2007 | 08:51 PM
deadline's Avatar
Default Re: del sol si d16z6 vtec not engaging (MR_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR_SI &raquo;</TD></TR><TR><TD CLASS="quote">you have to reallllly have an ear to hear a stock d series vtec engage. i mean u can feel it but BARELY. </TD></TR></TABLE>
Old Feb 1, 2007 | 10:41 AM
Eg2707's Avatar
Old Feb 5, 2007 | 09:57 PM
Eg2707's Avatar
bump for more help
Old Feb 6, 2007 | 07:59 PM
Eg2707's Avatar
Old Feb 6, 2007 | 08:21 PM
sol2hatch's Avatar
have you checked everything else that has been mentioned? Bumping this is not going to get your car fixed, IF anything is even wrong with it.
Frost_1097
66
Jan 15, 2007 07:00 PM
k20rex
15
Feb 26, 2006 10:09 AM
idriveadelsol7
Aug 21, 2005 09:46 PM
89 pos
11
Dec 6, 2004 07:25 PM
delsolrmp
Nov 15, 2003 07:46 AM
