trim levels of delsol
Re: trim levels of delsol (89 pos)
I beleive the Del Sol came as the S, the Si, and the VTEC. The S was the base modle, and had a D16 non vtec motor. The Si had the D16Z6 vtec motor. And the VTEC had the DOHC B16A3.
Re: trim levels of delsol (smithenhiven)
yes tha tis right except for 93-95 del sol was a d15b non vtec
there are several good del sol information threads here
http://www.hondavision.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smithenhiven »</TD></TR><TR><TD CLASS="quote">I beleive the Del Sol came as the S, the Si, and the VTEC. The S was the base modle, and had a D16 non vtec motor. The Si had the D16Z6 vtec motor. And the VTEC had the DOHC B16A3.</TD></TR></TABLE>
VTEC model? both Si have VTEC the D16z6 and the B16A3, the newer Si comes with the B16 and the older has the D16z6...I think the Si with the B16 started in 97(year with no foglights) but I am not 100% positive because I don't care about Del Sol, so never really cared to know anything about them.
Re: trim levels of delsol (R33CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R33CIVIC »</TD></TR><TR><TD CLASS="quote">VTEC model? both Si have VTEC the D16z6 and the B16A3, the newer Si comes with the B16 and the older has the D16z6...I think the Si with the B16 started in 97(year with no foglights) but I am not 100% positive because I don't care about Del Sol, so never really cared to know anything about them.</TD></TR></TABLE>
I'm not 100% sure, I know there was a VTEC trim level, and it had the B16. Maybe you're right about the older ones.
yeah the older ones had the D16z6(older Si models) the new del sols(Si models) have the B16...like I said, I think it started in '97 cuz that is the year without the foglights in the front bumper. but someone else on here can confirm the year change with the B16 in the Si.
Info from this thread: https://honda-tech.com/zerothread?id=700334
B16a3 info:
Displacement (cc): 1595
Power (bhp@rpm): 160@7600
Torque (ft/lbs@rpm): 111@7000
Compression Ratio: 10.4:1
Bore (mm): 81
Stroke (mm): 77.4
Cam Design: dohc
VTEC?: yes
OBD: 1
Year(s) Produced: 1994-1995
Tranny Info
Del Sol S
Year(s) 1993-1997
Engine Counterpart: d15b7
Type: hydro
Limited Slip Dif.?: no
Gear Box:
1st: 3.25
2nd: 1.761
3rd: 1.172
4th: 0.909
5th: 0.702
6th (if availble): 0
Reverse: 0
Final Drive: 3.888
Del Sol Si
Year(s) 1993-1995
Engine Counterpart: D16Z6
Type: hydro
Gear Box:
1st: 3.25
2nd: 1.9
3rd: 1.25
4th: 0.909
5th: 0.75
Reverse: 0
Final Drive: 4.25
del Sol VTEC S21
Year(s) 1994-1997
Engine Counterpart: B16A3 / B16A2
Type: hydro
Gear Box:
1st: 3.307
2nd: 2.105
3rd: 1.458
4th: 1.107
5th: 0.848
Reverse: 3
Final Drive: 4.4
94 & 95 Weights
EG 1994 Honda del Sol S MT 2301
EG 1994 Honda del Sol S AT 2387
EG 1994 Honda del Sol Si MT 2414
EG 1994 Honda del Sol Si AT 2474
EG 1994 Honda del Sol VTEC MT 2491
EG 1995 Honda del Sol S MT 2295
EG 1995 Honda del Sol S AT 2387
EG 1995 Honda del Sol Si MT 2414
EG 1995 Honda del Sol Si AT 2474
EG 1995 Honda del Sol VTEC MT 2522
B16a3 info:
Bore (mm): 81
Stroke (mm): 77.4
Cam Design: dohc
VTEC?: yes
OBD: 1
Tranny Info
Del Sol S
Year(s) 1993-1997
Type: hydro
Gear Box:
1st: 3.25
2nd: 1.761
3rd: 1.172
4th: 0.909
5th: 0.702
Reverse: 0
Final Drive: 3.888
Del Sol Si
Year(s) 1993-1995
Type: hydro
Gear Box:
1st: 3.25
2nd: 1.9
3rd: 1.25
4th: 0.909
5th: 0.75
Reverse: 0
Final Drive: 4.25
del Sol VTEC S21
Year(s) 1994-1997
Type: hydro
Gear Box:
1st: 3.307
2nd: 2.105
3rd: 1.458
4th: 1.107
5th: 0.848
Reverse: 3
Final Drive: 4.4
94 & 95 Weights
93: S, SI
94: S, SI, VTEC
95: S, SI, VTEC
96: S, SI, VTEC
97: S, Si, VTEC
thats it... S and SI's are all D-series
VTEC trim is a b16a3
[edit] damn someone beat me to it, and did a better job o well [/edit]
94: S, SI, VTEC
95: S, SI, VTEC
96: S, SI, VTEC
97: S, Si, VTEC
Actually some 96 came without the fog lights too. And all Si trim had a D16 vtec, the only one that came with a DOHC was the Vtec trim.
93-95 Del Sol's...
93-95 Del Sol S - D15B7 SOHC non-VTEC - OBD1
93-95 Del Sol Si - D16Z6 SOHC VTEC - OBD1
94-95 Del Sol VTEC - B16A3 DOHC VTEC - OBD1
96-97 Del Sol's...
96-97 Del Sol S - D16Y7 SOHC non-VTEC - OBD2a
96-97 Del Sol Si - D16Y8 SOHC VTEC - OBD2a
96-97 Del Sol VTEC - B16A2 DOHC VTEC - OBD2a
96-97 Del Sol's...
Re: trim levels of delsol (jL iLLuZiOnz 9)
well damn, you learn something new everyday.
to the guys posting up the correct information for the original poster!
Modified by R33CIVIC at 10:55 PM 12/6/2004
89civicb16a1
05-20-2006 09:50 PM
1MeaNDeLsOL
07-24-2003 06:10 PM
Sterling
12
07-17-2002 06:12 AM
