how to ID sohc vtec computer?
i want to know how to ID sohc vtec ECU?
I think my del sol might be vtec, but the vtec dose not work.
the valve cover does not say it is vtec, but it is a d16z6.
and i found what i think is a vtec silnode
Re: how to ID sohc vtec computer? (k20rex)
you have vtec. your ecu should have a tag with a bar code on it, somewhere on there it should say p28. thats the ecu you shoould have. why do think your vtec is not working?
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20rex »</TD></TR><TR><TD CLASS="quote">i want to know how to ID sohc vtec ECU?
and i found what i think is a vtec silnode</TD></TR></TABLE>
If it's a D16Z6, it has VTEC.
How have you determined that the VTEC isn't working?
Re: how to ID sohc vtec computer? (Civicse)
i can not tell a vtec turn over point like in my b16 and also as i thought that sohc reved to 7100 so i was thinking that it did not work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20rex »</TD></TR><TR><TD CLASS="quote">i can not tell a vtec turn over point like in my b16 and also as i thought that sohc reved to 7100 so i was thinking that it did not work. </TD></TR></TABLE>
I have driven a few sohc vtec engines and I have never been able to tell when vtec hits. Most people who have driven both say the difference is night and day. Get the pinouts for your ecu, hook up a 12v light to the wire controlling vtec and see if it lights up when you hit 5500 or thereabouts, should tell you if the ecu is sending a signal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20rex »</TD></TR><TR><TD CLASS="quote">the only code i see on my ECU is a P06. is this a vtec ECU?</TD></TR></TABLE>
Just saw this post, p06 is a non-vtec ecu,
that is not a vtec ecu....This can be found on my dx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicse »</TD></TR><TR><TD CLASS="quote">is there an echo in here?</TD></TR></TABLE>
Just we post at the same time in here or something
well you have a vtec engine with a non vtec ecu, what you need is a p28 ecu, thats what you should have
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20rex »</TD></TR><TR><TD CLASS="quote">it look like someone has cut and taped my ecu wires. here is my hole </TD></TR></TABLE>
I think all dx harnesses look like that. My friend got some plugs for me from the junkyard and when I got them I was like, WTF, and he said they were all like that.
before you spend money I'd pull the cover off the ECU, there are a lot of P06 ECUs out there that have VTEC capability added to them later.
There are a lot of scenerios that could explain this...
previous owner did a head swap due to floating valves, VTEC CELs, swap in P06 to be done with it.
Previous owner had a bad ECU for what ever reason, drops in an Ebay special that's upgraded like I mentioned and goes on with his life.
also they could have swapped in a lesser ECU before the sale and sold their P28 for extra money...
check to see if you have a VTEC solinoid on the head before assuming you have the ability.
95GSRBOI
10
09-13-2005 01:34 AM
1MeaNDeLsOL
07-24-2003 06:10 PM
