idel problem
Old Jan 25, 2007 | 06:34 PM
mikeym's Avatar
Default idel problem
I have a obdll gsr motor that is ideling funny. it was fine one day then the next it just started 2 rev up and down like to 1300 then drop back down. do you know what the problem is? it is not a vacuum leak and it is not my i-ac.
Old Jan 25, 2007 | 06:36 PM
Ldc4S's Avatar
Default Re: idel problem (mikeym)
are you low on coolant?
any air bubbles in your coolant?
checked your spark plugs lately?
Old Jan 25, 2007 | 06:42 PM
veggiemaster's Avatar
How do you know its not the IACV? it could also potentially be the FITV.
Old Jan 25, 2007 | 06:50 PM
dc2_88's Avatar
ob2 i believe they dropped the fitv and the iacv controlls the warm up also. I may be wrong though.... i would check my coolant for air, check the intake maniflod and throttle body for air leaks. check the sensors on the tb for air leakage also..
Old Jan 25, 2007 | 09:19 PM
DC2 Mang's Avatar
Default Re: (dc2_88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2_88 &raquo;</TD></TR><TR><TD CLASS="quote">ob2 i believe they dropped the fitv and the iacv controlls the warm up also.</TD></TR></TABLE>
yes that is true
check the IACV, that is usually the cause of about 80% of idle problem cases
and as said, check all of your vacuum lines, and your throttle body gasket as well
stockracer
Apr 6, 2010 08:15 PM
duscar
Feb 25, 2008 02:24 PM
tpatt
Apr 28, 2007 05:21 AM
mikester_91
Jan 21, 2005 07:33 PM
vxhatch02
Jan 27, 2004 08:33 PM
