Help with my 00 si coupe
Old Jan 24, 2007 | 08:10 PM
paowa's Avatar
Default Help with my 00 si coupe.. RPM/engine problem
for some reason, my car RPM is goes below 1000 on idle. when i gas then let it idle, it seems like the engine is about to die, then it slowly pick up power again. Anyone got any answer to this? THanks!!!!
Old Jan 24, 2007 | 08:14 PM
JDM_EK_wanabe's Avatar
Default Re: Help with my 00 si coupe.. RPM/engine problem (paowa)
try checking all your vac lines first, make sure they are all connected
Old Jan 24, 2007 | 08:39 PM
raphael's Avatar
inspect and if neccessary remove any engine grime from the iacv
Old Jan 24, 2007 | 10:46 PM
cstylez's Avatar
mine goest to 500 rpm some times, i think its the way the motor is * shurg
Old Jan 25, 2007 | 12:04 AM
djshift's Avatar
my si used to sit around 700 as well...the gsx i used to have the same problem, when u give it gas and then let go, it went way down and sputtered and them shot back up, i believe the problem was something with the fuel pump or fuel filter, also check your vac lines-Shift
Modified by djshift at 10:44 PM 1/29/2007
jermo
42
Oct 26, 2010 03:23 AM
riceforlife
Jun 13, 2007 11:13 PM
paowa
Jan 24, 2007 08:30 PM
Insane Si Lum
Feb 8, 2006 02:14 PM
Milano00Si
16
Feb 28, 2005 10:45 AM
