stock gsr turbo setup
Motor Setup
-JDM GSR motor
-GSR trans with OEM LSD
-skunk 2 intake manifold with Hondata gasket
-aftermarket clutch and 12lbs flywheel
Turbo Setup
-Garrett 57 trim .60 . 63
-AFI ramhorn
-Tial 38 mm WG with .05 bar spring + Turbonetics MBC
-3in down pipe
-Spoolin intercooler piping kit 2.25" from TB to outlet, 2" from turbo to inlet
-HKS SSQ BOV real thing
-wide 6in JRC intercooler
-RC 550cc
-Walbro pump
-P28 running on chrome pro
I am looking to boost off the .05 bar spring daily and have it up to 10psi at the track with a boost controller. I am planning on making around 300whp at 10psi.
I'm wondering how it works to adjust my boost from .05 bar off the spring to 10psi. Would I need a different chip with the 10 psi program?
Also I am looking into 3in exhaust with a cat and muffler or would a cat be a big power loss?
Thanks
-JDM GSR motor
Turbo Setup
-AFI ramhorn
-3in down pipe
-RC 550cc
-Walbro pump
Thanks
As far as adjusting your boost setting, get your initial tune on the higher boost setting, then lower your boost. And with a scramble mode on your electronic boost controller you can have high boost with the touch of a button, or just turn down a manual controller.
Switching chips for different boost levels is retarded, and will also cost more considering that the tuner will have to do multiple tunes, costing you more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK H47CH »</TD></TR><TR><TD CLASS="quote">I'm wondering how it works to adjust my boost from .05 bar off the spring to 10psi. Would I need a different chip with the 10 psi program?
just run a highflow cat.. wont matter. also when tuning you tune to a boost level, at 7psi it reads from xxx columns.. from 14psi it reads from xxx columns.. If your only boosting 8 or 9 or whatever (anything under that youve tuned) it will only read up to those columns.. Now if your using different fuels then you will need 2 maps. I suggest not doing your own tuning.
you could control boost via boost controller. at best by using electronic boost controller EBC. good ebc will allow several settings from spring to highest boost level. i guess generally you do'nt want to run double of what your spring is rated for.
hondamonkey
Aug 15, 2007 05:47 AM
xtremeness101
Apr 16, 2005 09:30 AM
