Rotor Replacement.
Old Jan 24, 2007 | 06:36 AM
phatmonsters's Avatar
Default Rotor Replacement.
My rotors are warped and i am going to replace with brembo rotors.
Do i need to bleed the system? and ive seen some comment about using a c clamp for the brake piston, what exactly are you sopoose to do with c clamp.
thanks
Old Jan 24, 2007 | 06:48 AM
doublejz's Avatar
Default Re: Rotor Replacement. (phatmonsters)
bleed brakes lines is one of the most over looked thing to do. Every time i change breaks I bleed them and can almost always feel a different in the pedal. my $.02
the C clamp is used when there is too much pressure to push the piston back into the caliper by hand. You can also open the bleeder instead if you are going to bleed the brakes anyway
Tenzo
Suspension & Brakes
May 24, 2012 01:04 AM
speedfreek128
14
Feb 26, 2009 10:01 PM
Chief Brody
Jun 12, 2004 10:48 AM
integrakilla
12
May 5, 2004 05:08 AM
Inaniac
Jul 4, 2002 01:18 AM
