Rotor Replacement.
Rotor Replacement.
My rotors are warped and i am going to replace with brembo rotors.
Do i need to bleed the system? and ive seen some comment about using a c clamp for the brake piston, what exactly are you sopoose to do with c clamp.
thanks
thanks
Re: Rotor Replacement. (phatmonsters)
bleed brakes lines is one of the most over looked thing to do. Every time i change breaks I bleed them and can almost always feel a different in the pedal. my $.02
the C clamp is used when there is too much pressure to push the piston back into the caliper by hand. You can also open the bleeder instead if you are going to bleed the brakes anyway
integrakilla
12
05-05-2004 05:08 AM
