built b18c losing oil, help !
Old Jan 23, 2007 | 11:17 PM
Cyber ITR's Avatar
Default built b18c losing oil, help !
heya guys
i just checked my oil level earlier and its right on the bottom hole of the dipstick
i topped up about a quart around 500miles ago to the full mark and now its gone down
the engine is fully built with brand new gaskets, seals etc.
ive done the compression test and its on 200-210psi
when i WOT the car i could see some greyish smoke screen from the rear view mirror, but i would assume thats because im running rich ( car is tuned with open e-cutout and i never open the e-cutout on the street )
i cant see any visible leaking from the bottom of the car, and the engine probably only done about 3000miles tops
help
Old Jan 23, 2007 | 11:26 PM
Cyber ITR's Avatar
Default Re: built b18c losing oil, help ! (Cyber ITR)
im running valvoline VR1 10w-40 by the way
Old Jan 24, 2007 | 09:09 AM
Cyber ITR's Avatar
help ?
Old Jan 24, 2007 | 09:33 AM
slooogsr's Avatar
Was it just built? How many miles?
From what i read on h-t you can expect some blowby from the rings not seating completely yet. However im not sure if you should be losing that much.
Old Jan 24, 2007 | 01:54 PM
Cyber ITR's Avatar
Default Re: (slooogsr)
yeah built with je pistons, eagle rods etc
engine probably done about 3000miles top
please help
Old Jan 24, 2007 | 03:54 PM
Code's Avatar
Not now Chief, I'm in the F'n zone!
Default Re: (Cyber ITR)
I'm guessing you're turbo right? If so, after you built you motor did you break it in with Dino oil? from what I've found synthetic lubricates too well to break the rings in properly, so you could be geting some blow-by. You could also have a turbo seal going out.
Old Jan 24, 2007 | 03:58 PM
Fo-Do Fanatic's Avatar
Default Re: (Code)
i do believe you are supposed to break your motor in with mineral oil, it seats the rings better than synthetic.
did you do that?
maybe you just got a bad seal on something even though you may have replaced it. dont over look anything
Old Jan 24, 2007 | 07:57 PM
Cyber ITR's Avatar
Default Re: (b00sted-Hatch)
i break-in the motor with a special running-in oil from valvoline
and i was running the engine for about 1000miles roughly before switching to semi-synthetic valvoline VR1
i hate this car, it keeps giving me troubles
Old Jan 24, 2007 | 08:14 PM
Muckman's Avatar
Moderator in Chief
Do you know what the ring gap specs are?
Old Jan 24, 2007 | 08:16 PM
Cyber ITR's Avatar
Default Re: (Muckman)
i wouldnt have a clue to be honest
but the engine builder said its kinda on the lose end because i told him the power i want the engine to be making
Old Jan 24, 2007 | 11:53 PM
Cyber ITR's Avatar
boink for help
hondaon18's
May 13, 2013 09:13 AM
Haleiwa-Brando
Aug 31, 2005 04:35 AM
SOHCD16y8
Aug 27, 2005 03:07 PM
Shwanky420
Aug 22, 2005 01:26 PM
Blazin Si
May 20, 2003 06:52 AM
