HMT kit w/ td04 13c turbo on a GSR
Old Jan 20, 2007 | 03:37 PM
bigsubs's Avatar
Default HMT kit w/ td04 13c turbo on a GSR
I just pick up a td04 13c off a 960 volvo turbo for $50 no shaft play or nothing good shape, will this work pretty good on a GSR block w/ USDM ITR pistons and rods??? Also does anybdy know any specs on this and whats its wastegated @???
Old Jan 20, 2007 | 03:46 PM
Schister66's Avatar
Man U FTW
it will work, but its going to die up top....
Old Jan 20, 2007 | 03:55 PM
bigsubs's Avatar
when you say die, will it run out of boost, or will it make me lose power over all, as if I was running all motor on the top side?
Old Jan 20, 2007 | 05:01 PM
rhamlinii's Avatar
Don't waste your time, you can so get many better thing for cheap. Why would you get junk?
Old Jan 20, 2007 | 05:40 PM
OnlyHJC's Avatar
Default Re: (rhamlinii)
arent u runing hi compression with the itr pistons?
Old Jan 20, 2007 | 08:26 PM
HiProfile's Avatar
Default Re: HMT kit w/ td04 13c turbo on a GSR (bigsubs)
It will feel more like the volvo you pulled it from - nearly zero lag, but fun stops at 5k.
You'd be better off with a 14b, or just a 50 trim t3 you see on ebay all the time. I have 4 of those atm. Some people collect baseball cards, I collect shitty turbos.
juice61993
Mar 15, 2011 06:27 PM
shabam
May 13, 2009 11:54 AM
Sp00nFed EM1
May 5, 2008 12:33 PM
sladed16y8
38
Feb 26, 2007 05:59 PM
ahemming06
Nov 28, 2006 10:08 AM
