Stuck Lug Nut
Old Jan 18, 2007 | 04:18 PM
EKHWhat's Avatar
Default Stuck Lug Nut
One of my lugs nuts is stuck on my front right wheel.
I replaced the studs, and three of them held perfectly.
One has a lug nut on it like half way, and the stud isn't in the hub all the way. The lug nut won't come off, and I can't get the wheel off.
Any ideas?
Old Jan 18, 2007 | 04:22 PM
onephatcivic98's Avatar
Default Re: Stuck Lug Nut (EKHWhat)
if you can get ahold of a air chizel than use one of them and get on the edge of the lug nut and go to town. if that done work break the stud is about the only option.
Old Jan 18, 2007 | 04:29 PM
egmatt93's Avatar
Default Re: Stuck Lug Nut (onephatcivic98)
break it and replace it
Old Jan 18, 2007 | 04:36 PM
EKHWhat's Avatar
How would I break it though?
I don't especially want to mess up my wheels while doing this.
Old Jan 18, 2007 | 05:36 PM
Jigoku Z's Avatar
Default Re: Stuck Lug Nut (egmatt93)
Just keep trying to back it out... until it gets really tight and keep going a little more and it will break
Old Jan 18, 2007 | 05:39 PM
Syndacate's Avatar
Default Re: Stuck Lug Nut (Jigoku Z)
If it wasn't so close to the wheel I'd tell you to heat it.
On that note, what are you using to get it off?
Any access to air tools is good. Even if you can bring it to a shop, a nice shot w/ an impact at 600psi should take the sucker right off.
Even so, get a long *** breaker bar w/ an impact socket and slap a piece of PVC piping on it and you got a nasty lug nut breaker.
Old Jan 18, 2007 | 05:55 PM
EKHWhat's Avatar
you guy's aren't understanding what i'm saying.
The lug nut is on the stud. Not all the way. The whole thing still has play in it, and the lug nut is tight on the stud (somehow).
Im not sure how it got in this situation, but it did.
I'm thinking try to drill out the stud some, then get a lug wrench and snap the stud. Then put in a new stud.
prelude_93vtec
May 8, 2008 08:22 PM
kyteggy
Feb 5, 2006 01:39 PM
shooitzlinh
Mar 20, 2005 06:44 PM
sloazzbimmer
Mar 16, 2005 07:48 AM
ITACivic
11
Apr 14, 2003 04:41 PM
