need advice on turbo lude set up
Old Jan 18, 2007 | 02:33 PM
brokenlude's Avatar
Default need advice on turbo lude set up
i just need to know if it is possible to run 3.6psi on stock injectors on a 97 prelude i have a vafc controller to adjust the fuel i just need to know if the injectors can handle that small amount of boost, thanks ahead of time for any info given
ps.. i all ready have 550cc injectors but i want to know if i can get by on the stock ones for now i am still building the motor i am actually going to use for my turbo set up
Old Jan 18, 2007 | 02:43 PM
Revi's Avatar
Default Re: need advice on turbo lude set up (brokenlude)
3.6 psi? You serious? I fart more psi than that! What kinda turbo you plan on running for 3.6psi? And you dont even have to build the motor up for that........
Old Jan 18, 2007 | 04:58 PM
brokenlude's Avatar
Default Re: need advice on turbo lude set up (Revi)
once again this is just for now and thanks for answering my question i really needed to know what psi you can fart.
Old Jan 18, 2007 | 05:43 PM
flight50's Avatar
in other words, he is saying that is extremely so. usually 6-7psi is the low for a stock h22 that isn't built. i am sure you probably could run 3.6 if you had a wastegate that could support it.
Old Jan 18, 2007 | 06:17 PM
DfwBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brokenlude &raquo;</TD></TR><TR><TD CLASS="quote">once again this is just for now and thanks for answering my question i really needed to know what psi you can fart. </TD></TR></TABLE>
https://honda-tech.com/zerothread/316373
Old Jan 18, 2007 | 06:25 PM
98vtec's Avatar
moderator emeritus
Default Re: need advice on turbo lude set up (DfwBB6)
is there even a spring for that low of psi?
Old Jan 18, 2007 | 06:29 PM
DfwBB6's Avatar
Default Re: need advice on turbo lude set up (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">is there even a spring for that low of psi?</TD></TR></TABLE>
hahaha yeah i thought that was weird he didnt even say 3psi he was sooo sure he wanted to run 3.6psi
Old Jan 19, 2007 | 10:15 AM
championshipwhite93si's Avatar
too funny.... yes you can run it to answer the question..subscribed, just to see what flaming ensues
Old Jan 19, 2007 | 04:48 PM
DCxMagus's Avatar
dude don't skimp out on a fuel solution like that
VAFC isn't good for boost it's been explained a million times but basically your fuel and timing maps are "corrected" inversely and dependently with that device &lt;-- VERY bad for a boosted motor.
any turbo worth mention won't hold 3.6PSI your going to have boost creep on the H22a trying to run that low of boost.
if you do use an FMU the stock injectors MIGHT be able to handle that low of boost bu against he boost creep is going to set in and your fuel pressure is going to be through the roof.
just wait till you can get a standalone like Hondata get those 550s in there and drive around knowing you don't have a band aid holding your fuel system together.
the lowest spring I believe Tial has is a 3.5psi spring its the small yellow one.
But to answer your question NO the stock fuel set up on of ours should not be handling ANY boost, I'm sure it will hold up for a while but your destroying your engine from the inside at that point.
Old Jan 19, 2007 | 05:35 PM
TDCTyler's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brokenlude &raquo;</TD></TR><TR><TD CLASS="quote">i just need to know if it is possible to run 3.6psi on stock injectors on a 97 prelude i have a vafc controller to adjust the fuel i just need to know if the injectors can handle that small amount of boost, thanks ahead of time for any info given
ps.. i all ready have 550cc injectors but i want to know if i can get by on the stock ones for now i am still building the motor i am actually going to use for my turbo set up </TD></TR></TABLE>
you should probably just wait......
Old Jan 19, 2007 | 09:21 PM
flight50's Avatar
Default Re: need advice on turbo lude set up (DCxMagus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCxMagus &raquo;</TD></TR><TR><TD CLASS="quote">dude don't skimp out on a fuel solution like that
But to answer your question NO the stock fuel set up on of ours should not be handling ANY boost, I'm sure it will hold up for a while but your destroying your engine from the inside at that point.</TD></TR></TABLE>
dude there have been many people running boost on completely stock h22's without problems. tuning is your insurance to your motors life. get a good tuner that know what he is doing. some even push it past 6-8psi. but if you do, your playing with the life of your engine.
Old Jan 20, 2007 | 12:30 PM
DCxMagus's Avatar
Default Re: need advice on turbo lude set up (flight50)
yeah but those people arent trying to run the stock fuel system on the stock engine.
if you just throw a turbo on an H22 and drive down the street there is a good chance its not going to make it back down the street lol
Old Jan 20, 2007 | 01:50 PM
TurboBB6's Avatar
Spoolin97 what kinda numbers u putting down? Thanx!
Old Jan 20, 2007 | 02:28 PM
flight50's Avatar
well you did say fuel system. my bad. i am only thinking about internals.
Old Jan 20, 2007 | 04:49 PM
compdog694u's Avatar
anything worth doing is worth doing right... Just be patient and wait it out.
Old Jan 22, 2007 | 04:39 PM
TDCTyler's Avatar
Default Re: (TurboBB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboBB6 &raquo;</TD></TR><TR><TD CLASS="quote">Spoolin97 what kinda numbers u putting down? Thanx!</TD></TR></TABLE>
im making 312whp and 230 wtq. thats on our dynomite land and sea dyno which reads 10% on average lower than a dynojet or mustang.
Adam R.
Feb 19, 2013 07:38 PM
jestin91
Feb 10, 2013 08:40 AM
fg10
Feb 17, 2010 09:25 PM
lookout22
Jan 9, 2009 06:32 AM
Turboredteg
Jan 26, 2005 02:19 AM
