P28? used for vtec dohc swaps? possible? or not?
planning for vtec.
buddy of mine said use p28 ecu. its good.
but for dohc? its for sohc.
can it be used? can it be better than p72?
or should i just use my p72 ecu?
need help. thanks.
need help. thanks.
you'll need to chip the p28. You may need to chip the P72 as well depeding on if you are running all of the oem GSR sensors, secondaries etc. Chipping them allows you to use DOHC VTEC fuel and ign maps and disable any sensors which have been removed.
