P28 ECU chipping
Old Nov 10, 2002 | 09:33 PM
jdmEKhb's Avatar
Default P28 ECU chipping
If i want to reprogram my P28 can i do it myself, or is there other stuff i have to add into the board? If i get a ROM that is setup up with DOHC VTEC parameters is that all i need? Also if I were to chip an OBD1 P72 are there any programs that still have IAB or will the IAB point be modified? Thanks in advance.
Old Nov 10, 2002 | 10:31 PM
salbaje's Avatar
Default Re: P28 ECU chipping (jdmEKhb)
You can definitely do it yourself. just make sure you got all the necessary components.
Old Nov 11, 2002 | 09:55 AM
Kataku2K3's Avatar
Default Re: P28 ECU chipping (salbaje)
Yea but do you just buy a DOHC VTEC ROM, then drop it in the P28???
Old Nov 11, 2002 | 11:19 PM
Kataku2K3's Avatar
Default Re: P28 ECU chipping (JDMspecEG6)
Where's Katman.... hehehe
Old Nov 11, 2002 | 11:43 PM
poison's Avatar
ask Katman, or B18C-EJ1 (adam), or Kenji on that, they would definitely know
Old Nov 12, 2002 | 09:04 AM
CHEETAH's Avatar
yes, you can do it yourself if you buy the eprom for your ecu type. If you're good at soldering then you can do it.
The gsr ecu is easier to program, add the two chips and jump, P28 is lil more, 1 10k resistor and 2 .1 picofarad capacitors needed.
good luck
greg
Old Nov 12, 2002 | 09:07 AM
Kataku2K3's Avatar
Default Re: P28 ECU chipping (CHEETAH)
Cool I've chipped ECU's before..... just never a GSR or P28... I think I should be able to do it.. Thanks for the help!!!!!!!!!
nfieldzy12
Apr 12, 2012 12:48 AM
thecruzs2007@yahoo.com
Mar 9, 2011 09:56 PM
hondcura2000
Jun 25, 2009 01:30 PM
sihatch1.8
Feb 4, 2003 04:13 PM
