speedomoter broken
Old Jan 15, 2007 | 07:31 PM
evade this honda's Avatar
Default speedomoter broken
did a clutch install last week and now all of a sudden my speedomoter stops working. Now I have a cel. I have a del sol with a 00 civic si swap... please help did search but nothing came up
Old Jan 15, 2007 | 07:34 PM
Zeusfire69's Avatar
Default Re: speedomoter broken (evade this honda)
Did you plug in the speed sensor, or did it get broken/pinched?
Old Jan 15, 2007 | 07:35 PM
I Shot 50 Cent's Avatar
Did you plug the VSS back in? Its a sensor that is located on the Transmission housing.
VSS is the Vehicle Speed Sensor. It would definitely keep the speedo from working if it is broken or not plugged in.
no it was workin this afternoon when driving but when I left my friends house it just stopped working and through the light
Old Jan 15, 2007 | 07:42 PM
it did this right after I did the clutch install but then it fixed itself. Now its doin again a week later
Old Jan 15, 2007 | 07:43 PM
The VSS is #8 & 9
here you can see it on the right side of the tranny which is the closest side to the firewall
Pictures thanks to B18CivicEG from a post a few days ago. Hope it helps.
Old Jan 15, 2007 | 07:48 PM
my question is why would be goin hay wire after a week. its never done that before plus my sensor doesnt look like that
Old Jan 15, 2007 | 08:04 PM
I need more help... I would rather not take it to honda if i can fix it myself.
Old Jan 15, 2007 | 08:06 PM
EX-T's Avatar
Default Re: (evade this honda)
The pins inside the plugs are probably all corroded away.
Kris05TSX
Transmission & Drivetrain
11
Jun 25, 2024 10:04 PM
Lucky_Smurf
Apr 20, 2005 12:22 PM
bg-33p
Feb 12, 2005 10:33 PM
SPOON_FED_DC_2
Jul 29, 2004 01:13 AM
