oil filter fitting and the block coolant drain plug?
Old Jan 12, 2007 | 10:58 PM
redboost10's Avatar
Default oil filter fitting and the block coolant drain plug?
i have a gsr block that had a oil cooler on it before, i found the part numbers on hondaautomotiveparts.com for the oil filter fitting male to male to get rid of the oil cooler section, and i found the part number for the plug and washer. just wanted someone to verify the part numbers please. and assure me this is what i need eventhough they are honda part numbers for a gsr block ( i know honda makes the block).
oil filter fitting male to male 18309
coolant drain plug 28mm (picture shows the drain plug in the front of the block, but im assuming the back is the same) 18342
drain plug washer 28mm 18349
thank you
gATOr65
Jul 4, 2008 05:21 PM
redboost10
Jan 13, 2007 12:46 PM
SkoundrelUSA
Aug 23, 2006 08:42 AM
INCNTRL4
10
Jun 29, 2006 07:32 PM
johnzm
Dec 9, 2004 10:14 PM
