Cars not starting
Old Jan 12, 2007 | 01:20 PM
2ndGenREX's Avatar
Default Cars not starting
I just replaced the spark plugs and the spark plug wires and now the car is not starting, it turns over but does not want to start....all my connections look good, what could it be?
Old Jan 12, 2007 | 01:22 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: Cars not starting (2ndGenREX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndGenREX &raquo;</TD></TR><TR><TD CLASS="quote">I just replaced the spark plugs and the spark plug wires and now the car is not starting, it turns over but does not want to start....all my connections look good, what could it be?</TD></TR></TABLE>wires aren't run right. That's my guess. Or you forgot the screw on the rotor(you wold probably hear some kind of strange noise with this though) .
Old Jan 12, 2007 | 01:24 PM
2ndGenREX's Avatar
Default Re: Cars not starting (ILcrxsi1)
car ran for a couple seconds then died.....i'll recheck the plug wires but i'm pretty sure they are on right
busted240's Avatar
spark, fuel, compression. You are missing one of those. If you have spark, check fuel. Check your fuel pressure, make sure your fuel pump is turning on. If fuel is there and spark is there, do a compression test. Then go from there.
Old Jan 12, 2007 | 01:26 PM
ILcrxsi1's Avatar
Default Re: (busted240)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by busted240 &raquo;</TD></TR><TR><TD CLASS="quote">spark, fuel, compression. You are missing one of those. If you have spark, check fuel. Check your fuel pressure, make sure your fuel pump is turning on. If fuel is there and spark is there, do a compression test. Then go from there.</TD></TR></TABLE>I'm going to guess that it has something to do with spark
Pics FTW!
Old Jan 12, 2007 | 01:27 PM
menappi's Avatar
Did you gap the plugs? I don't think they come pre gapped.
Old Jan 12, 2007 | 01:30 PM
2ndGenREX's Avatar
no i just tightned the plugs so they were tight but not to tight.....how do i gap them? *sorry never done spark plugs b4*
Old Jan 12, 2007 | 01:34 PM
ILcrxsi1's Avatar
Default Re: (2ndGenREX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndGenREX &raquo;</TD></TR><TR><TD CLASS="quote">no i just tightned the plugs so they were tight but not to tight.....how do i gap them? *sorry never done spark plugs b4*</TD></TR></TABLE>most are pre gapped. where did you get them from?
Old Jan 12, 2007 | 01:56 PM
2ndGenREX's Avatar
Default Re: (ILcrxsi1)
autozone......valucraft spark plugs they were like 1.39 each. Just called and ask, autozone said they <U>are not </U>pregapped. Looks like thats the problem....
Old Jan 12, 2007 | 02:43 PM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndGenREX &raquo;</TD></TR><TR><TD CLASS="quote">autozone......valucraft spark plugs they were like 1.39 each. Just called and ask, autozone said they <U>are not </U>pregapped. Looks like thats the problem....</TD></TR></TABLE>should have got ngk's from the stealership
Old Jan 12, 2007 | 02:45 PM
busted240's Avatar
not that this has anthing to do with the problem, seeing as it is solved... I just thought i would make a point abou the spark fuel compression thing. If it was spark, its pretty easy to tell. but just because a car is cranking and cranking and not starting isnt always spark. on my rx7 it turned out to be the fuel filter.
Glad you fixed the problem
Old Jan 13, 2007 | 01:50 PM
menappi's Avatar
The point he was tryingto make is you need three things to start the car, spark, fuel, compression. It had to be one of those.
bassamillion
Honda Civic (2001 - 2005)
Jun 20, 2018 05:55 AM
intake
Dec 12, 2006 09:16 AM
e jay one
Mar 4, 2006 06:02 PM
95dx
13
Nov 25, 2003 01:29 PM
