Gasoline in the spark Plug wells??? WTF
Old Dec 11, 2006 | 08:07 AM
intake's Avatar
B A N N E D
Default Gasoline in the spark Plug wells??? WTF
ok my car wouldnt start..
so we removed the spark plug wires.. and found them in gasoline.. the spark plug wells floooded.. Why would this happen?
How can i fix this problem to get my car started?
new dizzy is coming.. new spark plugs.. what else>?
Old Dec 11, 2006 | 11:04 AM
jays93eg6's Avatar
Default Re: Gasoline in the spark Plug wells??? WTF (intake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intake &raquo;</TD></TR><TR><TD CLASS="quote">ok my car wouldnt start..
new dizzy is coming.. new spark plugs.. what else&gt;?</TD></TR></TABLE>
The reason for the fuel in the head would be that when you turn the key the fuel pump primes it self and begins pumping fuel. If you keep trying to crank the car it will keep pumping fuel to the cylinders, so it floods itself. If the plugs are new just clean them off and let them dry, they should be ok.
Old Dec 11, 2006 | 05:26 PM
B6tPoweredMx3's Avatar
check the oil see if it smells of gas, and change it.
Old Dec 11, 2006 | 08:55 PM
Muckman's Avatar
Moderator in Chief
Default Re: Gasoline in the spark Plug wells??? WTF (jays93eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jays93eg6 &raquo;</TD></TR><TR><TD CLASS="quote">
The reason for the fuel in the head would be that when you turn the key the fuel pump primes it self and begins pumping fuel. If you keep trying to crank the car it will keep pumping fuel to the cylinders, so it floods itself. If the plugs are new just clean them off and let them dry, they should be ok.</TD></TR></TABLE>
That doesnt explain how gas would get on TOP of the cylinder.
Old Dec 11, 2006 | 09:02 PM
BuddhaSiR's Avatar
so we removed the spark plug wires.. and found them in gasoline.. the spark plug WELLS floooded.. Why would this happen?</TD></TR></TABLE>
Gasoline should not be in the WELLS/spark plug tubes. You have something really weird going on or your not describing it right.
usually oil is found in the spark plug tubes when the tube gaskets leak.
Old Dec 12, 2006 | 08:01 AM
intake's Avatar
B A N N E D
Default Re: Gasoline in the spark Plug wells??? WTF (BuddhaSiR)
how would i replace the tube gaskets then?
Old Dec 12, 2006 | 09:16 AM
BuddhaSiR's Avatar
Take the valve cover off.
justinCO
Jun 5, 2008 08:19 PM
skata89
May 21, 2006 03:32 PM
e jay one
Mar 4, 2006 06:02 PM
QTKEG6
Jun 23, 2002 10:14 PM
